AC Delete
AC Delete
I just removed the compressor and hoses from my factory air 68, it didn't really work anyway. Heater hoses were already removed when I bought it. However I do want the heater for fall & early spring driving. Can I simply hook the heater hoses back up to have functioning heat? Or do I have to use some kind of AC delete kit? TIA
interpon (05-16-2022)
if you go to the trouble of putting moulded preformed hoses on and may or may not find a leak... or may want no water in hot weather.. i would instal 2 shut off valves one on each hose just in case...so you can at least have the option
many threads on this
Stevewv (05-16-2022)
Often times the heater core hoses are bypassed due to a leaking core. Be prepared for that possibility.
