Dakota Digital RTX
Cruising
Dakota Digital RTX
Edited Feb 18/2023: Read to the end of this thread. Kudos to Dakota Digital for listening and redesigning the gauges.
Do NOT buy Dakota Digital gauges for a 1978 - 1982 Corvette. They would be awesome gauges, but you can't see the top 1/3 of the speedometer and tachometer due to them being too far back from the glass and blocked by the bezel. Your eyes need to be about 9" above the seat in order to see the entire speedo and tach.I spent thousands of dollars for amazing gauges that I cannot see. Dakota Digital really needs to redesign their gauges for 78 -82 Corvettes.
Received 4,548 Likes
Cruise-In VIII Veteran
Good to know.
Wow, that sucks for such awesome looking gauges. Thanks for the heads up. I hope you've called and made your concern known. Not sure how they could do it, but hopefully somehow they make this right!
Cruising
just need to redesign th drivers so eye level is just below the steering wheel rim...
Cruising
Interesting, I have installed Dakota Digital into several other types of cars with great success (no C3 though). In your opinion, where did they go wrong? their gauges are normally designed to to fit exactly like the originals into the original bezels.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
They look awesome and I can see there not for C3, what a shame.
Cruising
Great News! Dakota digital has agreed that the MTX RTX gauges have a viewing angle problem and are looking into re-engineering them! Looks like I will be taken care of. It will take them some time to produce and test the new prototype, but once I have the new gauges I will look into deleting this thread, as it will no longer be appropriate.
NONN37 (05-06-2022)
Totally different gauges for the 73 v 78. Bummer for me, was getting ready to purchase. What I don't understand, these have been around for years and now your the second person to point of the problem.
don't delete the thread. reopen it with the update and their appropriate kudos.
SteveG75 (02-19-2023)
Cruising
Cruising
The following 2 users liked this post by Richard81:
interpon (02-18-2023),
Quicksilver78 (02-19-2023)
Pics of revised?
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Kudos to Dakota Digital for redesigning the rtx-78c-vet and mtx-78c-vet gauges! I just took the Corvette out for a first drive since having the redesigned gauges installed and the visibility of the top part of the gauges is vastly improved. Still not perfect for a tall driver like me, but at least acceptable. I'm 6'2", so I would think that drivers 6' and under would have no issue at all, and taller drivers can live with these gauges as they are now. Not so happy with the extra expense I incurred for having the gauges replaced, but still grateful to Dakota Digital for stepping up and fixing the problem. As the starter of this thread, I would like to change the title from Dakota Digital RTX - Don't Buy!, to Dakota Digital RTX - they fixed the problem! Does anyone know if this is possible? I have not been able to find a way to edit the title of the thread.
Ask a mod, they can handle this
