Tool Advice
Tool Advice
I am going to be replacing front wheel bearings on my '70 Corvette. I need to buy some bearing race drivers. Any recommendations of where to buy? Thanks
hammer and a straight punch. largish one.
Received 3,149 Likes
Brass drift and a hammer. I also use a small "dental"mirror so I can see if the race is full seated
M
ntfday (02-16-2022)
Harbor Freight works fine. I got a complete set for 32.00
interpon (02-15-2022)
Dr. Detroit
Received 3,893 Likes
Why don't you pull the hubs and inspect if you need races first? I have packed about a thousand front wheel bearing in my life and had bad races on exactly two cars in 35 years.\
Jebby
Jebby
Received 1,299 Likes
I would say the front inner and outer bearings and races can be purchased in matched sets.
Front Inner: Timken SET5 Rockauto $6.85ea X 2 = $13.70
Front Outer: Timken SET3 Rockauto $6.43ea X 2 = $12.86
Front Inner Seal: Timken Rockauto $6.50ea X 2 = $13.00
TOTAL LESS SHIPPING $39.56
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
If it ain't broke, don't fix it! If you follow that logic you will save thousands in unnecessary parts/repairs. But if you have the money.................
The following 2 users liked this post by resdoggie:
forman (02-16-2022),
sunflower 1972 (02-16-2022)
you see where Bmoto put Timken? your current bearings will last longer than new ones from ebay or amazon. pull and check yours. if rollers and races are not pitted, you have that many more all original parts...
The following 3 users liked this post by derekderek:
resdoggie (02-16-2022)
One more thought.
Does your local auto parts store loan tools? I know Oreilly's locally does. Don't know if they have bearing drivers.
Or take the rotors and new bearings to your local auto machine shop and have them press them on.
May be an old wife's tail but I heard its important to keep the new races and bearing together as they came from the supplier.
