Steering Column Movement
Good afternoon all, and Happy New Year!
I'm hoping to get an education on steering columns and the repair of.
My steering column moves up and down, not terribly, but enough that I want to repair it.
I've checked the obvious, bolts under the dash.
When you hold the steering wheel you can move the upper portion up and down. I suppose it may have been used to many times to get in and out of the car, I don't know.
My car is a 73, auto 350. The steering wheel is a tilt/tele.
I appreciate any help I can get on what the problem may be and how to address it!
Thank you.
Eric
Thank you.
Eric
Thank you.
Eric
Thank you.
Eric
I believe it's also in the Chassis Rebuilding Manual for the '73.
I recently had Mike Denapole restore my '69 column, and since it's a safety device, I'm surely going to follow the mandatory sequence to a T.
southwind (01-05-2022)
Emerging Vendor
The column usually is loose due to 2 reasons:
Tilt knuckle bolts(4) have loosened and need to be retorqued
The tilt knuckle and/or lock housing pivot pin holes are enlarged. Usually just the left side. Oversize pivot pin can be used.
Greg
Greg
__________________
Greg
Greg
Eric- (01-05-2022)
The column uses 3 brackets to mount it. The middle bracket is adjustable to set the "up and down" position. It is a wedge so it can be moved forward and backwards to raise or lower the column position. I bet yours is loose.
Eric- (01-07-2022)
I watched a couple videos of tearing down the column, looks a bit like a nightmare.
This is probably what's wrong with yours , especially as you say its just the upper section . Good news is ,if it's just the 4 bolts loose , its just some locktight and a re-tighten , unfortunately its almost a full pull down to get at it ..
bazza77 (01-07-2022)
The 4 big screws hold an alloy block solid to the lower tube , that's the alloy block that has the holes that the tilt pins seat into . Looks like you have to take out the LARGE tilt compensation spring next ,levers and that lock pin again ! then the tilt pins , then watch all the bearings fall out while you remove the lower housing section. There's two small sleeves that fit over the top bearing one solid and one split , they can bind up on the way out and when it goes back together ( when you have the tool on the lock plate , trying to get the big C clip back on so watch for that ) Never tried to go that deep while in a car , I imagine the original bearings will give you hell ,(the modern ones from Zip have a better cage that holds everything together nicely )
Once that big tilt spring is out you should be able to work out what's loose anyway.
