Vacuum gauge question??
Hey all,
Quick Question . . . . . .
I need to buy a Vacuum Gauge. I've never had one. No idea if they are all kind of the same or some better than others. I am looking for suggestions. I do not want junk. I do want quality but realistically don't need professional or super high end.
My immediate use is I need to test the vacuum from my LS7 to see if I can support brakes AND headlight functionality. I've been told my assumptions are incorrect and the best way is to simply test the vacuum.
So, anyone here that can point to a decent gauge on Amazon, I'd appreciate it!
They pop up at around 18-35 bucks which seems reasonable. I'm happy to step up to the more expensive one if there is predicted future uses or if the quality requires it! If the 18 bucks one is perfectly fine I am good with that also!
Thanks for any input! I appreciate the guidance!
This one seems well rated and lots selected it. Not stuck on this one, just liked the ratings.
Scott
Scott
Popular Reply
10-05-2021, 05:57 PM
Received 3,150 Likes
It was one of these
Made a new face for it in adobe illustrator and used a needle from another oil pressure gauge I had then an angled bracket to hold it where the clock was... A fair amount of screwing around but, well why not
M
M
That is a good quality gauge. OTC is a reputable company. It's also a pressure gauge (15PSI). Go for it.
I have a old "crapsman" (craftsman) vac. gauge that about 45 years old and still works.
69_Shark (10-05-2021)
I have a vacuum gauge in every car since the 70's. I call it "looking into your lover's eyes" lol.
1. Determine diameter I recall that 2 1/16th is standard and they also have 'miniature sizes' such as 1.5" Dia.
2. Then you want a 'fluid filled' gauge...they last longer and the vibrat-ey excursions are damped out (JEGS/SUMMIT)
3. Mounting bracket config.
4. Piping....you want relatively thick walled flexible tubing...thicker the wall the better.
5. You want to 'Tee off' of manifold vacuum as close to the source as possible. Be careful of 'tiny T's'...again the vacuum propagates at the speed of sound...keep the 'bores' open.
Good luck learning your lover!
Unkahal
Unkahal
LOL!
I already do that with my boosted ford. LOL! I added a permanent gauge just to watch the turbos! ford was to cheap to provide one in my PU! Or rather . . . I was to cheap to spend 75K on the more expensive truck with that gauge!
It is my first and only rig with a fixed vacuum gauge though!
Scott
Scott
With much screwing around I managed to get one of the autogauge ones to blend into the stock gauges where the clock used to be
I've got several for setting the engine up and I usually never worry about the numbers (accuracy) as much as which way the needle is moving and when. This one is probably the only one I have that is actually accurate, I should check it to the others someday
M
M
Mooser-Baby! Great job.... I had to look TWICE!
Dish on which gauge that was! (link)
THX UNKAHAL
THX UNKAHAL
Jarhead 74 Vette (10-07-2021)
It was one of these
M
M
Damn! You're ****! lol...but well worth it....super job! The gauge that Chevy shoulda, coulda, woulda!
unk
unk
Harbor Freight has them...as do many auto parts stores. E-bay, amazon, etc. etc. Vacuum gauge is very useful for diagnosing Internal combustion engine performance...and for diagnosing vacuum system issues. Read up on how to use it and how to 'read' it. The action of the needle movement is more important than the vacuum level showing on the dial.
M
M
M
M
I have a cheap Harbor Freight vacuum gauge. I dont use it all that much anymore, as everything I have is now converted to fuel injection, but it has always worked good.
If I was using it every day, I'd definitely get a hood name brand one, but for something just to have tucked away it's fine.
There's a lot of NICE in that picture right there
M
M
