What are you guys installing in place of a front license plate
My state doesn't have front license plates anymore , what are you guys doing in place of a license plate ?? it kinda looks naked without a plate , mostly concerned with something that matches my white Vette and not stick out or draw too much attention
Eric P (06-21-2021)
Sorry , my 1980
'Murca! I see @interpon had the same idea.
The 80 really needs a plate of some kind.
EDIT Better photo.
EDIT Better photo.
Eric P (06-21-2021)
If you have a 1970-72, you can extend the center grill out by 4 inches and get this look....
Beats the license plate look!
The following 5 users liked this post by 7T1vette:
Chuck72 (06-22-2021),
Jarhead 74 Vette (06-22-2021),
Jebbysan (06-22-2021),
loup68 (06-23-2021),
Tranz Zam (06-22-2021)
Eric P (06-21-2021)
augiedoggy (06-22-2021)
The following 4 users liked this post by Jason Staley:
Nam Labrat
Received 4,216 Likes
(sorry.....I have a case of
Yes. Four (4) 4 inch extension posts (ie, 3/4" aluminum rod), each tapped and threaded for the same threads as the mounting bolts for the center grill. The posts can be of any configuration that will fit with clearance required. This could be round, square, hex or any other cross-section material that you have available. I chose aluminum as it will not corrode badly and is easy to machine.
