Where can I get rotor runout shims?
I've tried several vendors all were out of stock. The brand I found was Raybestos. Are there others out there?
https://www.summitracing.com/parts/AGB-BA80306
Received 3,223 Likes
I just use aluminum cans - a cheap punch and die set plus some scissors my wife keeps in the kitchen that are really sharp...just make sure to put them back!!!
.004" thickness
.004" thickness
bluthundr (04-18-2021)
I use the same punch set that Richard shows and shim stock kit from any industrial supplier. I bought the last shim stock kit for about $60 - almost 20 years ago and used it for 100's of rotor dial ins. For doing one car it would cost you about $80 or so for the punch and shim kit. If you do a lot of work they come in handy if it's a one and done maybe not so much. There used to be industrial supply stores open but many are gone now but you can probably find small shim stock packages online or possible at an good parts or hardware store for much less.
All depends on how much runout you have and how you retain the rotors. If just using lug nuts that will change every time you rotate the wheels. Most times the runout is under 008" and shims will work, I have got the runout down to under 001 at times with new rotors and the way I refinish the flanges and hubs. I like anything under 003" so getting to 002 is where I usually end up but I also bolt them on the flange or hub.
Awesome thanks!!!! Ordered
I have to ask, this may seem like a stupid question. How does a 1 shim which is placed on the hub onto the all the studs, make any difference? I assume the shim is the same thickness throughout? I always thought you would add individual shims to the studs only to reduce the run out or even it up. For example (hope I explain it clearly) let's say 12 o'clock is 0 degrees and 6 o'clock is .008 degrees out. Meaning it stick out .008. Wouldn't you put shims at the 12 o'clock to bring that closer? I realize you need support at the other studs. I am just trying to keep this simple.
Nope,,, the shims are not the same thickness. They are clocked and tapered. DOH
My question for the OP,, why are you thinking you need shims? Bad brakes?
FYI The rated shim thickness is not the actual difference in the thickness of the shims. What it means is that the rated thickness will translate into the difference towards the outside of the rotor.
So, say a 3mm shim will only be maybe .5mm difference from side to side, but will make the rotor 3mm difference at it's outside edge.
Have new rotors and rebuilt calipers. My runout has been .005 and 6 on the fronts so far. I do not see having to ever do a pad change again given the amount it's driven so I'lll sweat the little details on this.
Here's a good video on using this type of shims-
Hopper12 (04-20-2021)
I might check mine just for kicks.. Let us know if it makes a difference. Could you feel it in the pedal?
Beer can?
Steel shims would be better next to steel parts.
I'll just throw this out, although it may not be your issue. But it's worth knowing about:
I went through a situation recently where I tried to shim a rotor and I could NOT get the rotor to shim properly no matter where I rotated it or placed the shims .....and I've shimmed many rotors in the past.
Turns out, after a LOT of attempts and head scratching, I determined the new rotors (made in China ..from RockAuto), there's a bevel at the inside edge of the rotor at point where the outer edge (where the outer hub face meets) ...a rounded bevel, the way the rotors were machined. This effectively doesn't allow the rotor to fit all the way onto the hub (due to the bevel). Therefore no matter where I rotated and bolted down the rotor, each time it would lay different on the hub (but never completely fitting 'flush' against the hub face). The original rotors were machined with a square-cut inner edge and the hub fits almost to the very edge.. After a lot of head scratching I reversed the rotor/s (put it on backwards) and the runout per the dial indicator was almost zero!
This is the kind of situation that could throw off a lot of Corvette owners into thinking their rotors are 'off'. So beware. You may need to do some checking/measuring. If you notice this, you can either grind a slight bevel on the outer 1/16" of the hub, or get different rotors that are machine-cut square inside.
Also, I've always just made my own paper shims of various thickness paper to meet the need. Use a little anti-seize on the hub surfaces. I've done it for years. The paper will absorb some of the anti-seize ...and won't 'rot' away. Hasn't for me. I've got some that I removed on some vehicles that I put on a hook and could eventually reuse.
Dementer sole survivor
Received 6,372 Likes
2016 C3 of Year Finalist
They make extensions that have the twist consistent with a torque setting. I know my boss had an impact gun that the torque could be run down on, then we would use a wrench to set the final torque. That was 40 years ago thou
Dr. Detroit
Received 3,893 Likes
