Tank Sticker
Tank Sticker
I own a 72 Corvette 454 / four speed
Besides the Tank sticker were there any other areas of the Corvette where the documentation was placed?
(Behind the dash?)
Vic
(Behind the dash?)
Vic
1967 Pedal Car Champion
Yes, behind the dash is one spot you may find it. I've also heard of them stuffed under a seat. I found mine behind the driver side dash.
Found my '72 LT-1 Build sheet over the right rear body mount when I removed the carpet.
I know of a '69 L-88 where they rinsed the inside of the frame before restoration and a second build sheet washed to one of the openings in the frame.
If you can't find a second build sheet take a closeup photo and try manipulating the photos - darker, lighter etc..My tank sticker was very hard to read/ torn but doing this and comparing it to a legible build sheet from that year I was able to decipher all the lines
