Does a stock 1978 L82 need a zinc additive ?
Location: I buy all my days at the same place where the girl sells her nights
Does a stock 1978 L82 need a zinc additive like zddp ? If it needs one how much needs to be added? How often does it need to be added?
if you use regular oil yes , if you use something like Valvoline VR1 or equivalent for old cars it will have the proper amount of zinc content
Earthquake Driver (03-22-2021)
Received 2,145 Likes
Any engine that is not a roller lifter should have Zinc.
Zinc has been around since the 1940s to prevent premature bearing failure of crank, rod & cam bearings. Long before flat tappets were even around.
The lovely tree huggers EPA removed Zinc from motor oil in this century. There was no ad in the paper. No ad in magazines. Nothing on TV / Radio. It just happened by Govt officials and deadlines without warning.
Tractor oil was the last to go down of "off the shelf zinc oil". Break-in oil showed up later with a label: Not For Street Use.
Today, numerous oil companies brought back the Zinc for the thousands upon thousands of older vehicles needing Zinc.
Several posters use an Zinc additive. Myself, I just buy the oil already with Zinc.
Received 6,995 Likes
2015 C2 of Year Finalist
you need API C category OIL BRAND DOES NOT MATTER
Earthquake Driver (03-23-2021)
Throw some diesel oil in it brand doesn't matter and enjoy the ride.
my go to chart.. i buy the 1300 minimum.. and the cheapest.. which currently is walmart 15-50 1300 zinc phos.. 24 bucks for 5 quart jug
i can post because i read the oil sticky..
and my name is tom and i have a stock L82
mobil-1-product-guide-rev-31.pdf
Zinc motor oils | Mobil™
The following 2 users liked this post by interpon:
Earthquake Driver (03-23-2021),
Vette5311 (03-23-2021)
In 1979 I rebuilt the engine (289) in the 66 Mustang I gave my grandson, It has made a couple of trips back and forth to Cherry Point, NC (Marine Corps Base) has over 100,000 miles and has never seen anything other than Pennzoir 10W/30.It stills runs strong and no smoke.And it doesn't have hardened valve seats and is running a fairly stout cam ( Comps installed about 10 year ago). The quality of the components, no chinesium junk, can not be understated. If it makes you feel better run ZDDP, but too much can cause as much damage as none or not enough.
Another vote for Walmart Mobil 1 15-50. Relatively inexpensive and very accessible. I have four flat tappet Corvettes-all on Mobil 1. Moderate NC climate and I don't drive them when its really cold so the 15-50 is not an issue for me.
Current formulations of STP include ZDDP.
The following 2 users liked this post by Kev73:
LenWoodruff (03-24-2021)
I use Valvoline VR1 20w-50 in my 78 L82 that was rebuilt a few years ago per the engine builder.
Earthquake Driver (03-24-2021)
1967 Pedal Car Champion
<now where did I put my soapbox? ah, yes, here it is...>
As much as we bemoan the EPA, would you rather no one monitors industry and its effects on the population and environment? I would suggest that the EPA has led us to a cleaner, more efficient world by forcing engineers to research more deeply and be creative in solutions. I'm old enough to vividly recall the daily yellow/brown haze over Los Angeles, Love Canal, and the burning of the Cuyahoga River (which actually happened 13 times since 1868). In another thread I mentioned the 2020 Corvette doing 0-60 in ~3 seconds while getting 15/27mpg -- all of this while conforming to the EPA requirements. Both of my Corvettes kill thousands of brain cells/second by just being near the exhaust outlets and there's no way they can even dream of 3 second times. The old days weren't all that great.
<putting the soapbox back in the closet>
https://www.mobil.com/...has-zinc-been-removed-from-motor-oils
https://cen.acs.org/articles/84/i31/ZDDP-motor-oil.html
The following 2 users liked this post by 67:72:
Earthquake Driver (03-24-2021),
MrTriTanium (03-27-2021)
