To Heat delete or not....that is the question
Received 2,705 Likes
I drove my restored 77 for four seasons in Western Pennsylvania without heat. When I rebuilt the car, I installed a new heater core, but never hooked it up. This last winter I got it all connected, with an NOS heater valve, and looking forward to extending my driving season. There were days early and late in the year, that we didn't take it out cause it was just too cold. I am looking forward to having it. One year on the way home from Corvette Carlisle, I could have used the defrost, and now I will have it. Although, all it took was a quick wipe with a towel, so not really a big deal. Maybe someday I will install the windshield washer system,....but I doubt it.....RainX and avoiding rainy days probaby is enough. And if I get caught in the rain,....the wipers work.
On my 67 Nova project from a few years ago the some what primitive defrost did not dry the air but totally kept the wind shield clear with warm air in 80 plus air temps while non defrost cars were totally fogged over.
Thanks again everyone, I was reading that a lot of people were having problems with the car getting to hot inside, but I suspected that it's predominately from the exhaust rather than the heater.
I'm going to take the advice of many and go with just replacing the heater core and hopefully I can get those couple of vacuum lines operating the dampers for the defroster and the heater itself...
Received 3,223 Likes
Here it is on Amazon-
But look else where (unlike my wife...) and you can find them for half the price Amazon wants.
APPARENTLY... (read: i've not done this yet) you can buy really nice aftermarket heaters. The Jeep guys love these little heater systems. Easy to install, cheap enough, simpler than factory, and they do everything they're supposed to. This is my plan. I'm a weight-reduction spaz... i salivate at losing all that factory heater mess weight, and gaining the space. Those little aftermarket heaters are small too, and they weigh VERY little. Something around $2-300 i think? I live in Canada. Even the mildest winters in Canada re winters. Where i am, its WET... so deleting entirely is impossible. If i lived in a dry state? Yank. Toss. Duct-tape up the holes. Done.
Dementer sole survivor
Received 6,378 Likes
2016 C3 of Year Finalist
The Fall car shows start early ad have to be on the road early to get there for a good spot and registration.......so when I leave there can be frost on the ground, a good working heater and defroster are very important on those days. My 327 never got the interior warm but I replaced the carpet and used a thick pile under it which seems to keep the summer cabin heat down. Im hoping to put in a 427 this spring which could run the interior temps up which I hope does not happen. I run hedaman headers to the stock 69 style side exhaust so that may be why the exhaust heat doesnt get into the cabin too much. I would also second the water alve and bypass for the heater. Im going to do that mod as well since the motor is out.
I think you are on the right track with keeping the heater. Although all the electric options that the others have mentioned sound like a good idea as well, just more work
c5c6c7 (03-01-2021)
doorgunner (03-02-2021)
AC, too!
Man, i'm still shopping for a CAR! But i had this stuff all mapped out for my last build, which was a Mopar. Same trick though. I THINK (???) it was a Flaming River system? I remember it was 2.2lbs total. A quick search on google fired me towards Summit and i found 12 different brands there. Shouldn't be a hard nut to crack.
I looked at aftermarket electric heaters- but with only 12V- the resistance type heating uses a ton of current- here's one but it requires 30-50A
https://www.ebay.com/itm/Demon-Tweek...-/302251941380
Electric AC- there are also several out there- but like the heater pull a lot of current- like 50A-below- that's what I am running-
#33
They all require using engine coolant (Summit) except for a handheld -like I'm using for my defroster system or a "back seat" heater ( which I could have used in High school- just sayin!!!)
However the specs gloss over the BTU output- and it looks to pulls 25A.
https://www.summitracing.com/parts/rpe-3501
#34
Yeah, thats a given. I've never known even a big floorstanding electric heater to be ov any use. I'd never install one in a car. Maybe as an overnight heater in the winter, but that will plug into the house and require very litltle actual heat to be effective at keeping frost/fog off the glass. The one i saw had two simple hoses routed from the engine. Too easy.
