Alternator wiring... simple question.
I have a stock Delco 10si alternator. For my own satisfaction, I'm rewiring much of the engine compartment. My question with the alternation wiring is: why can't I run the #2 terminal (on the 2 wire connector) directly to the battery terminal on the alternator? They do both go directly to the battery+
according to this you can make that modification
http://www.oldengine.org/unfaq/10si.htm
We don't need no stinkin' dash light
Received 3,222 Likes
HOWEVER- You will be BYPASSING the fusible link- and will have the full power of the battery at the alternator terminal UNPROTECTED...and it the alternator output stud is connected to the horn relay then those wires are UNPROTECTED as well-
Saddlehorn (03-10-2020)
Good point but I'm not too woried about a unprotected shunt between the battery terminal and terminal 2.
If the alternator shorts out-while running- smoke comes out and it stops making power. A puff of smoke and no fire...
HOWEVER- if the battery sees a short - it's capable of over 700 A-which would easily melt a 8 - 6 even a 4 GA wire running through the engine compartment - near flammable stuff, And unlike the alternator- it continues to supply power- just like the energizer bunny!!!
The idea behind fuses are not to protect the device -but blow before the wire melts/catches fire.
An inexpensive- simple way to protect your electrical system is to fuse at the battery
Fusible links are the only protection to keep from melting wires- if removed -bypassed- nothing is protected. Electricity not only follows the path of least resistance - but ALL paths.
If you have an ammeter (early C3's) and you wire "around" the existing harness, the ammeter will no longer function. The "current shunt" is part of that wiring bundle.
This is not to say that you shouldn't do what you are suggesting. It's only to inform you that the ammeter will not longer be operational. You could change it over to a voltmeter and easily wire that into your 'modified' electrical system.
One reason for moving away from a fusible link for me- is saving a tow home. Can easily replace a fuse on the side of the road.
Here's you go- a nice clean solution- by "Blue Sea Systems" set up to handle a marine environment and not expensive at all
Do a search for
and then purchase the desired amount. for your 8 gauge lead you would want a 12 gauge fusible link per the following from google:
What size fusible link should I use for a 10 gauge wire?
For AWG sizes (wire gauges), each fusible link is four wire gauge sizes smaller than the wire it is designed to protect. For example: to protect a 10 gauge wire, use a 14 gauge link (or for metric, to protect a 5mm wire, use a 2mm link).
12 Gauge Fusible Link Wire
