Aftermarket Radio Mounting Plate Options - where to find?!?
Hi all -- trying to put an aftermarket radio in my 69 coupe. research pointed me to some good forum posts and I found the "American International FP-306" plate as the best way to go about mounting a typical aftermarket radio. But... I can't find it available for purchase anywhere! The only website that has it is a bonanza . com, and after I ordered it, never received and had to file a claim to get my money back...
Does anyone know a vendor where I can purchase this?
Can I fabricate one myself?
thanks all in advance!
How about selling the radio and buying something designed to fit, an example of one vendor below.
https://customautosoundmfg.com/produ...t=cam-cvmv-230
jonathand (01-20-2020)
It's a great idea! But I like the functionality of my unit and don't really mind cutting the bezel up and not striving for the classic look. If I really can't find anything and can't find a solution, might have to go that route however... thank you for the reply
jonathand
Here you go. Here is where you can order it and you can see some pics where I installed a while ago. https://www.corvetteforum.com/forums...post1583872412
And here are some pics I did last week when I installed a non-CD replacement (cheap one just to see if I like it), haven't played CDs in ages. I have a USB flashdrive that will store thousands of songs. Fascinatingly no depth. I will probably replace with one of those DIN 1 stereos that have a pop-up screen so I can install a rear view camera later.
Thank you so much! I actually found that thread and tried ordering through mobile-emotions, but my order was cancelled. It seems that the FP-306 product simply was discontinued. I cannot find it anywhere.
I may just have to figure something else out
jonathand
And here are some pics I did last week when I installed a non-CD replacement (cheap one just to see if I like it), haven't played CDs in ages. I have a USB flashdrive that will store thousands of songs. Fascinatingly no depth. I will probably replace with one of those DIN1 stereos that have a pop-up screen so I can install a rear view camera later.
Bummer. Did you give them a call to see what the story is?
jonathand
Here. These guys allegedly have one left --- not sure who they are, but if you need one you can ask quick. https://www.bonanza.com/listings/Ame...ics-/648848233
And I did find out part number is American Internation FP306 .... after looking around I also saw it mentioned in other posts on the forum.
I had the same issue with mobile emotions. The story is they bought several hundred a while back but sold out, would not be getting any more, and were considering making more out of aluminum but nothing was set. I suggested they remove it from their website to which they agreed when they figure out how. I decided I'm going to get some abs and fabricate my own. Worked on the template today. The measurements are rough but it's a start.
Side note: if you have a broken console (mine was at the poorly designed weak point), there is a fantastic fix using a product called Panel Bond. It's not cheap and you will need to fabricate some supports but it works!!
Location: Loud, Raw and Dangerous 1968 327 4S in Southern California
I searched for "C3 Corvette radio bezel" on ebay and found this. Ad says new item so maybe it is still available?!
https://www.ebay.com/itm/C3-Corvette...wAAOSwL9BeLbvp
Leave your stock radio, but disconnect it, and put a Bluetooth amplifier in instead. Like this Kenwood unit, or this Pyle unit for half as much, or any of a dozen others. I'm doing this currently in a non-Corvette.
If you do hack up your center console, please consider buying a used one that is already hacked up, or a new one that has the 1 DIN mount already.
AllC34Me (02-07-2020)
I have the same mounting arrangement and it worked out great. With a Kenwood media stereo, Sony replacement speakers, and a couple of Polk Audio bookshelf speakers in the back, I can blast out a clean sound even over the turbo mufflers.
Kenwood Stereo
Kenwood Stereo
very cool! Let me know how this goes please
carriljc (01-11-2024)
Bikespace (02-06-2020)
Bought a huge sheet of 1/8in ABS today and started to work.. Here's the result
Final result which looks pretty awesome for my first time..
Just kept trimming and fine tuning the fit..
4ftx8ft of ABS only cost $50!! Already thought of two more projects.
carriljc (04-27-2023)
