How do I repair this?
The filler (adhesive?) between the rear clip and the door jamb is cracked and missing in some spots. I was planning on just filling it with fiberglass and resin, but is there a better material to use? I have attached pics.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If the car were here in my shop I'd grind it out with what we call a dove tail bit, then we'd clean it out from the dust and apply (inject) Sems panel glue p/n 39747 and allow it to dry. This glue looks factory and can be finished out once dry.
The only issue is it takes a special gun to shoot this glue so you might want to follow the same instructions above and use something different like Vette Bond.
Willcox
Willcox
BlueL82 (11-21-2019)
Received 1,470 Likes
Cruise-In II Veteran
The following 2 users liked this post by Easy Mike:
BlueL82 (11-22-2019),
Willcox Corvette (11-21-2019)
The important word here is "some". Some/most do. High strength and slightly flexible.
https://discountdw.com/p-5750-which-...uld-i-use.html
Willcox
Willcox
Former Vendor
I highly doubt any urethane caulk would have the holding strength of the SEM product, the Sem product is a glue it one time and be done with it when dry.
IMHO,
Willcox
Thanks everyone for the input. I'll be going with the sems glue. The damage is quite drastic, the panel even can flex and the panel the t-top locks into is starting to pull away. I'd like to get the right product to seal it up and make a long lasting repair, now just to find an application gun, not really willing to spend 150+ on a gun I won't be using often, time to search eBay and others.
Thanks everyone
Thanks everyone
tutermoe (11-21-2019)
Hello everyone, I have an update. After trying to search for an application gun and realizing I'd be shelling out ~$200 for a one use tool, I figured the Vette Panel Adhesive was the way to go. I heard quite a bit about this Vpa, but this was my first time using it, the stuff rocks. Nice and easy to apply, and sands extremely easily. For the really bad spots, where the cracks on the rear clip used to be, I packed a 50ml syringe with vpa and injected it. Then, I'd let it dry and use my compressor to blow out the dried up vpa back out of the syringe, then use it again. Came out amazing, this stuff is now my go to.
Here are some pics of how the work turned out, The primer was being wet sanded in the last pictures. I'll have to post more after I apply color.
Thanks again, everyone. Also, something I learned and wanted to share, I would mask off the surrounding area. I had a few drips here and there.
The following 2 users liked this post by BlueL82:
doorgunner (01-20-2020),
interpon (01-20-2020)
