How to remove 69-76 Park Brake Console
I'm must be missing something simple. I've removed the (4) side screws, but it seems to be hanging up against the back carpeted panel. Help please before I bust something.
Russ
Russ
Center of back compartment - screw(s) go in toward front of car. (I believe that's what you are looking for!!)
Remove the jack and the removable bucket. The bolt has a 7/16" or 1/2" hex head on it. A 1/4" ratchet wrench and socket will remove the bolt from the backside of the bulkhead plate. It's a real PITA to remove that console, if you don't know about that bolt.
EDIT: Someone? in a previous post suggested screwing a short stud in place of the rear bolt. THAT'S what I'm going to do. Certainly eliminates future frustration.
