wheel dollies
wheel dollies
hello friends ,im thinking about getting a set of these ,anyone have these and do you like them ,I see they sell 10 inch ,and also 12 inch what is the difference? Bill
Are they a good brand name? As I'm sure you know, dollies are all about the quality of the castor bearings and wheels. I bought 4 of the less expensive type from a Harbour Freight type vendor. I'd say I got what I paid for but I actually I got less. I mostly use them separately as platform type rollers because they're almost useless for rolling a vehicle around. It's not a case of a few bad apples. All 16 of the castors on mine are terrible. They won't change direction unless I use a pipe wrench to twist all of the wheels around to the direction I want to go. Takes two people just to push a car in a straight line and even then it can be a struggle. Definitely a case of buy quality or don't buy at all.
Rescue Rogers (04-20-2019)
I was surprised to read the reply above, because I also bought the Harbor Freight dollies, and they work great. Made a simple job of spinning our car in circles when we converted the front half of the garage into a paint booth. While it`s true I have bought pure worthless junk from that store, most of it was related to electric motors. But their hydraulic and mechanical stuff has held up and worked fine for us.
Senior Member
Received 2,031 Likes
St. Jude Donor '10
I agree that it is all about the quality of the casters regardless of the brand or style you buy. I use heavy duty steel plate wheel dollies for mine and they work like a charm. Mine are not the hydraulic ones, I am old school I guess, I just jack my car up onto the steel ones and move it at my leisure.
Good luck with your decision and selection.
David Howard
AllVettes4Me
David Howard
AllVettes4Me
One thing you NEVER buy from HF is cutting tools-drill bits...
Location: Way too effing close to the city.......NRA Life Member!
I bought a set of 2 the Harbor Freight mechanical (not hydraulic) wheel jack/dollies and liked them so much I bought 2 more. They work great in my new garage.....almost too great! The car will roll with the slope of the garage floor sometimes so I have to be careful and aware. My garage floor is finished very smooth so that might be why it's so easy. It has cut stress lines. I imagine if the floor were a rougher texture with finished stress lines they might be hard to move around with a car loaded up,.So far, so good!!
I was surprised they were so bad too. Mine were from a store here in Ontario but they have the same stuff Harbour freight does. All 16 are crap so maybe a bad batch of castors slipped through at the factory? One thing I've learned is don't buy stuff like that unless you're ready to use it. I had the dollies too long to take them back or I would have.
oldgto (04-20-2019)
