Destroyed my Drivers Side Door
Old 12-02-2018, 08:15 AM
Burnt71
Burnt71's Avatar
Default Destroyed my Drivers Side Door
Backed my tractor into my 75 coupe. 2'ball and hitch destroyed the door but did no damage to anything else. What years are interchangeable ? I have access to used doors. Are convertible doors different ? all c3s except 68 should fit ?
Old 12-02-2018, 08:49 AM
Tooch1
Tooch1's Avatar
Hi Burnt71,
Sorry to hear about your misfortune. There is a difference in C3 doors if you want to be correct. Starting in 1973 GM added a side guard beam in the doors for added passenger safety. Because of this beam the door skin had to be molded to fit over it. Since you have a 75, you could probably use a 73 and later door on your car. Actually you could use an earlier door but it won't be as safe or correct. I've included a few photos to show what the inner beam looks like and what to look for in the door jambs. I'm sure the photos will be above my text, which I don't prefer, but for some odd reason that's how they post. Not 100 % positive but I don't think there's a difference in Coupe or convertible doors other than the jamb hardware.
Tooch
Hope this helps.
Burnt71 (12-02-2018)
Old 12-02-2018, 11:02 AM
'75
'75's Avatar
Starting in 78, the mounting for the arm rest and door pull are different also. That said, a 73 to 77 door would be the best fit.
Old 12-02-2018, 09:01 PM
derekderek
derekderek's Avatar
Received 3,387 Likes on 2,632 Posts
And coupe-vert diff is glass only.
Old 12-02-2018, 10:51 PM
71 Green 454
71 Green 454's Avatar
Received 1,186 Likes on 650 Posts
And also the door alignment pin.
Old 12-02-2018, 10:53 PM
NONN37
NONN37's Avatar
post pics of the damage. its probably repairable.
dont have to worry of new door fit and reinstalling componets to new one.
Old 12-05-2018, 05:35 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
reskin outer door better than replacing.
Old 12-06-2018, 12:52 AM
Sunracer
Sunracer's Avatar
Default this
yep ultimately a better choice if only the skin is damaged
To Destroyed my Drivers Side Door
Quick Reply: Destroyed my Drivers Side Door
