Driving Chevy's Experimental Turbo C3 Corvette
CorvetteForum Editor
By Brett Foote
Once upon a time, some engineers at Chevy took some boost and a few Corvettes for an ill-fated experiment.
By Brett Foote
From the article "That car used a modified L82 with an AIResearch T3 turbocharger producing 7 psi of boost." "Twin"?
1981 Yenko turbo
I bought this car a few yrs ago. It had a yenko turbo put on at the yenko factory. I have all the paperwork. Does anyone else know anything else about this car or set up?
[img]blob:https://www.corvetteforum.com/04a8b2af-7114-43ab-80e1-2314fe60d9e5[/img]
pdx-vette (06-22-2020)
The following 2 users liked this post by pdx-vette:
DarrellD23 (07-10-2020),
L-46man (08-05-2021)
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've got a couple setups somewhat like that (my forever under construction streetrod, and my '84 C4). My '84 is a similar draw through system, but with TBI and most of the induction plumbing is built into the manifold (Martin Turbosystem setup). Big block level power at 7psi, and works great on a road course.
Hopefully you're having some fun with that setup.
There were a couple companies in the late seventies that made kits like that. There is a two chamber (one above the other) spacer that fits under the carb that directs the carb airflow through the top chamber and then into the tubing you see behind the thermostat (that feeds the turbo compressor inlet), and then the compressor outlet pushes the air through the S shaped tube into the lower chamber of the spacer, that then feeds the pressurized mixture down into the intake manifold plenum.
Some kits (I don't recall if they all did) had a small poppet valve between the upper and lower chambers. It hung down by gravity (revealing a small hole/port between the chambers), so that at light-loads/low-throttle the A/F mixture from the carb could take the short route straight down from the carb through the poppet valve area, and into the manifold plenum, helping low RPM throttle response. At WOT, the compressor created enough pressure differential across the poppet valve to close it fully, making all the A/F mixture go through the turbo.
The turbo (Rajays were popular) is a special design, as it requires additional seals in the compressor due to it being a draw-through system (meaning the compressor is sometimes in vacuum, not just ambient or above ambient pressure as in blow through systems).
Jason Staley (06-28-2020)
So they trashed the ac?
i would love to see how they cut off the lines.
Dr. Detroit
Received 3,897 Likes
I thought this version was the best one.......blow through EFI......and none of the 80's flair
https://www.caranddriver.com/feature...hived-feature/
Jebby
Jebby
Jebby
Jebby
Received 3,043 Likes
St. Jude Donor '05
Bg from Los Angeles? Looks like Rajay?
