69 on cl looks off to me
PainfullySlow (06-18-2018)
Finalist 2021 C3 of the Year - Modified
Is it me or is that car really up in the air, especially the back.
Small tires? I could probably get under those side-pipes.
It`s not just you bats.... I bet she goes sideways down the road! And yes, looks like it has a lift kit on it too!
So look at the rear wheel picture
Are my eyes and brain playing games or does it look odd to you too ?
69 on cl
69 on cl
Car is just sitting way high on the frame. Front springs installed wrong? Wrong springs? Mono rear spring swap without extending bolts?
Rear wheel appears toed-in because it is a '69 which does not have a flare behind the rear wheels (IMO).
There are "problems" with the suspension. Could be minor; could be major.
‘All new suspension”. It looks high in the front and the back. It’s got 255/60 tires so they aren’t the problem. Front might be a little high because of the L98 heads.
I'm betting that it has new springs, which are causing it to sit high. That and I think it picture was shot using a wide angle lens, which will cause distortion at the outer edges of a picture.
That's a pretty ugly gap in the upper left corner, of the right side headlight door.
Dementer sole survivor
Received 6,370 Likes
2016 C3 of Year Finalist
my cars PO had mine toed in so bad I had black soot on my rear quarters so bad I thought I was burning oil . then I noticed the tires were bald by the end of the month....haha. After measuring it, it was toed in about 1.25 inches. That thing would jump to the side about 6 inches on every good size pothole.
For the pic, its probably a fish eyed lense or optical illusion, its way to obvious to be driveable
