1980 corvette body mount replacement
Old 05-07-2018, 09:13 AM
Robbie-T
Robbie-T's Avatar
Default 1980 corvette body mount replacement
Hi guys
its nearly time for dreaded body mount replacement.
i have a 1980 Manual L48 350 c3 Corvette
I’m from Australia Melbourne and I need help.
can anyone give me a step by step procedure of how to remove and replace the body mounts, including if I find rusted body mount brackets and how to replace them.
also what needs to be loosened and undone from the body to lift a side at a time to change the mounts.
Do I need to loser bumpers etc...
also where can I buy body mount kit and body mount bracket kits in case I have to cut them and replace them.
Any advice will be greatly appreciated
Old 05-07-2018, 11:22 AM
Lakeside49
Lakeside49's Avatar
https://www.corvetteforum.com/forums...on-1980-a.html
These should get you off square one. Good luck, myte
Old 05-07-2018, 12:10 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi RT,
What are you seeing that makes you think the body mounts need to be replaced?
Regards,
Alan
Old 05-07-2018, 11:23 PM
SciVette
SciVette's Avatar
Will be following...
Old 05-08-2018, 06:42 AM
Robbie-T
Robbie-T's Avatar
Originally Posted by Alan 71
Hi RT,
Regards,
Alan
had a look at them under the car and there getting pretty flat.
plus car has a slight lean to the passenger side, right side.
Old 05-08-2018, 06:44 AM
Robbie-T
Robbie-T's Avatar
Originally Posted by Lakeside49
http://youtu.be/mjAy4Cd5Ido
hi lake
I have seen this video, my car is a 80 model do I assume would be slightly different
Old 05-08-2018, 07:01 AM
Alan 71
Alan 71's Avatar
Hi RT,
I'd think a 'lean' to one side or the other is typically a suspension issue not a body mount issue.
I'd be looking at the suspension bushings rather than the body mount bushings.
Regards,
Alan
Old 05-08-2018, 10:00 AM
Grumpy 427
Grumpy 427's Avatar
I lifted the body completely off my 80 vette, and i had one broken nut cage on the frame to tack weld that was it. For a Canadian car i was amazed how little to no rust damage i had to repair. I went with all Polly body mounts when i put the body back down.
Spray as many of your body mount bolts as you can get too with A foam blaster or a rust loosener, let that sit for a day.
Old 04-27-2021, 07:18 PM
Floydy
Floydy's Avatar
Originally Posted by Robbie-T
hi lake
Robby-T, I know this thread is a few years old but wondering if you ever figured out how to lift the body on an '80 just enough to do mounts? There is some good info on earlier C3's around but it remains unclear what the procedure is for an 80. The factory service manual and assembly information manual is of little help. By the way I am from Perth but live in Nashville TN.
Thanks in advance!
To 1980 corvette body mount replacement
Quick Reply: 1980 corvette body mount replacement
