Edelbrock 1409 Carb Marine Application
Looking at a good Edelbrock 1409 for a good price, only thing is it's for a marine application. Would these work well on a 350 out of the water as it does for in water?
Thanks,
Thanks,
A marine carburetor will work perfectly fine on a non marine application and there is no difference in the tuning or set up.
You should never use a non marine carburetor for a marine application.
As far as the cfm and tuning for your engine and performance needs, I have no clue regarding if that particular carburetor will work with your set up and needs.
MISTERZ06 (05-26-2017)
