Coil Spring Compressor: 1-Piece or 2-Piece style?
It's probably been 10 years or so since I removed the front coil springs on my C3, so memory is a bit foggy. I do remember that I used a 1-piece style that grabs the spring on both sides at each end, but see that there is now a 2-piece style that uses a separate tool to compress each side (and assume a bit more forgiving in the limited space to work in???)
Anybody have experience w/ either of these 2-piece designs? Any pros/cons? C3, small block, standard spring.
http://shop.advanceautoparts.com/p/s...903/22986964-P
-or-
http://shop.advanceautoparts.com/p/a...0554/5932653-P
Thanks!
-or-
Thanks!
-or-
Thanks!
-or-
Thanks!
DR'76 (04-08-2017)
Received 2,878 Likes
Hi D,
I agree that a tool with a long threaded rod and a clamp of some sort that pulls the spring up into the frame pocket is a good way to install the front spring.
Be Careful... because the spring has a lot of stored energy when its compressed. Secure it to the frame while you're compressing it.
Be sure the ends of the spring are installed in the a-rm and frame pocket correctly and that the 4 close coils of the spring are 'up'.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
DR'76 (04-08-2017)
2 piece outside compressors are generally used on struts- springs out in the open. On a setup like a C3, where spring goes into a pocket, you need the 1 piece internal design
DR'76 (04-08-2017)
I use a 2 piece and take off the top part and run it up thru the shock bolt, then tighten it up and it will compress the spring. I also remove the control arm from the inside and leave the ball joint connected. I find it easier and safer that way. I also learned how to do it that way when I worked for GM 30 years ago.
DR'76 (04-08-2017)
I've used the two piece multiple times on my daily driver, but not my C3. It works great.
Also worth noting that Advance (and other auto stores) will rent you a spring compressor, you don't have to buy one.
DR'76 (04-08-2017)
Thanks for the replies and suggestions... didn't realize that the 2-piece style was more geared towards an external installation, so the 1-piece will probably be a bit easier.
