Hardtop attachment?
Hardtop attachment?
What type of "bolts" are correct to hold the 74 hardtop secure at the rear seal? Is it the same taper point like on the ragtop OR is just a threaded bolt, then using a washer and nut to secure?
Thanks....
Thanks....
Here's a good thread about hardtop studs vs pins:
https://www.corvetteforum.com/forums...top-studs.html
On my '71, I use studs/washers/nuts along with a center stud/washer/nut and 2 side bolts.
