Heat Riser vs No Heat Riser
Old 01-05-2017, 01:42 PM
JohnnieUtah
JohnnieUtah's Avatar
Default Heat Riser vs No Heat Riser
I have a stock 1974 Coupe that has a new heat riser plate on the exhaust manifold. It works fine but just wondering if I should remove it and replace with a plate-only version eliminating the thermostatic coil spring part. Right now I have a Weiand intake and Holley 650 with manual choke but I'm looking to make her stock with the cowl induction again. I have the stock intake and I'm getting the Q-jet soon. Just wondering how others are dealing with the thermostatic coil heat riser. Do most remove or keep it?
Old 01-05-2017, 02:21 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
no heat riser in warm climates, or if you have your exhaust crossover plugged your intake.
Old 01-05-2017, 02:26 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi JU,
If as you write your intent is to go back to the stock set up then having the heat riser installed below the right side exhaust manifold and the divorced choke installed on the intake manifold would be heading you in that direction.
An operating heat riser warms the choke coil faster which drops the idle down to normal operating rpm sooner.
Regards,
Alan
Old 01-05-2017, 03:03 PM
Revi
Revi's Avatar
I use a piece of safety wire to keep mine wired open all of the time, but it can take a bit of time for the choke to come completely off.
Old 01-05-2017, 06:13 PM
CanadaGrant
CanadaGrant's Avatar
I am not a big fan of running hot exhaust gasses through a cold intake manifold, especially an aluminum one. Below is a pic of the original aluminum "snowflake" manifold off my 69 427 L36 engine. The oil shield has been removed and that crack is right across the exhaust passage. The aluminum is so brittle from heat cycles it is actually falling apart and was not weldable. Heating up an intake manifold hot enough to actually boil the fuel in a carburetor after shutdown is not my idea of a good idea but I guess GM thought so at the time.
Old 01-05-2017, 06:50 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
Wow. Pumping exhaust into the galley to boot!
Old 01-05-2017, 07:23 PM
CanadaGrant
Yup. Must have been GM's first attempt at exhaust gas recirculation. I always wonder how many years it ran like that and almost didn't find it. I was cleaning out the intake and shone a light into the port and saw a line of light on the inside of the oil shield. With the shield on it isn't visible at all from the outside. There were a few cracks barely visible and only with the magnaflux type spray. You can see them branching off at the top of the big crack.
Old 01-05-2017, 07:25 PM
gcusmano74
gcusmano74's Avatar
IMHO, when you use an aluminum intake manifold on a garage kept car, a heat riser is not required. Seems to me we spend a bunch of good money putting free flowing exhaust pipes on the car, and a heat riser closes off half of it (at least until the car warms up). If you have an iron manifold, and the car is an "outside dog", you probably should keep the heat riser operational. My two cents.
Old 01-05-2017, 10:05 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Worse is that the heat riser valve is only 2" diameter on the later models, enough to choke a stock 350, let alone any kind of performance build.
Old 01-06-2017, 04:58 AM
terrys6t8roadster
terrys6t8roadster's Avatar
If you look closely there is a step in it and take a measurement of the ID of the heat riser it isn't even 1 7/8". T
Old 01-06-2017, 05:19 AM
Corvetteoz
Corvetteoz's Avatar
Hi all,
I'm a bit of a newbie to these cars. Do these cars only have one heat riser? I just got my original ram horns removed and replaced with some better flowing headers. There was only one heat riser on the exhaust.
Old 01-06-2017, 07:16 AM
bazza77
bazza77's Avatar
Originally Posted by Corvetteoz
Hi all,
yeah only one , it blocks off one side exhaust pipe and forces the exhaust gas across the intake manifold to help warm the carby(choke) during cold starts. As said above only (in your case) needed if you leave your car outside during a Melbourne winter ! I wired my old 350 one open , then put hooker side pipes on it and that got rid of it altogether.
Old 01-06-2017, 09:03 AM
Corvetteoz
Corvetteoz's Avatar
Thanks Baz. Here I was thinking some nuffy's taken the other one off at some stage and my chances of getting another would be zero. Wrong again
Old 01-06-2017, 12:41 PM
7T1vette
7T1vette's Avatar
Received 2,714 Likes on 2,272 Posts
Unless you leave the car outside and use it regularly in winter weather (I think that leaves 99+% of us out), the heat riser system is more of a risk than a benefit. The downside of having that riser valve freeze in 'closed' position greatly outweighs any gains in warm-up time.
Personally, I cut the valve off its shaft inside the housing. That way it all looks original, but it can never be 'closed'...either intentionally or accidentally.
oldgto (01-07-2017)
Old 01-07-2017, 06:09 AM
Corvetteoz
Corvetteoz's Avatar
That's a good idea to keep it looking original
Old 01-07-2017, 08:20 AM
oldgto
oldgto's Avatar
Great idea! I was planning to use stock replacement exhaust system.... and thought about that "gap" that would be created by eliminating the heat riser....but I didn`t want to "wire it open".
Old 01-07-2017, 02:29 PM
terrys6t8roadster
Willcox sells the piece without the butterfly in it, basically just a spacer. T
To Heat Riser vs No Heat Riser
Old 01-07-2017, 02:47 PM
Paul L
Paul L's Avatar
I can't find it. Do you have a part # for 2"?
Old 01-07-2017, 03:04 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Here it is Paul...
Exhaust Pipe Spacer - R.H. - 2"
Paragon Number: 730
1958-61 All 283 w/F.I.
1962-74 Substitute for S.B. exhaust heat riser valve.
Years: 1958 - 1974
photo courtesy Paragon Corvette Reproductions
https://www.paragoncorvette.com/p-35...acer-rh-2.aspx
Good luck... GUSTO
oldgto (01-07-2017)
Old 01-07-2017, 03:26 PM
Paul L
Paul L's Avatar
Originally Posted by GUSTO14
Here it is Paul...
Paragon Number: 730
Years: 1958 - 1974
Good luck... GUSTO
Thanks!
Quick Reply: Heat Riser vs No Heat Riser
