Modern Dash Question
Ok yes I did try doing an advance search but the results returned too many false positives.... so
I am thinking about doing a modern C5/6 Dash with instrument cluster and center console in my '68 resto. For the pure C3 owners sorry for hacking up a '68 but it was a basket case that would have never seen the road and was a great candidate for a restomod.
So back to the question has anyone attempted fitting a C5/6 dash with instrument cluster and center console into a C3?
Thanks in advance to any responses that helps
Received 3,222 Likes
The C5/C6 are wider- it can be done- but it's not going to be easy.
FWIW -C6 are CAN BUS which means its going to take a lot more noodling to get it to work...
Here's a C7 going in a 78- and he quickly found out that even the door locks were a challenge.
Richard
C7 in a 78
voidhead1 (08-25-2016)
Essentially nothing in a C5+ Corvette is directly operated. Everything is at least one layer of control away from the switches via a number of electronic control modules that all linked by "one wire" communication.
The PCM (power control module) acts as a sort of master and I don't believe it's possible to get any of the others working without a PCM installed. Beyond simply installing the PCM a number of its many inputs (none directly available in anything you propose) are required for the other modules to carry out their functions.
If you're going that route, why a C5/6? There are so many other cars out there with way nicer dashboards and gauges, I can't imagine going to all that work for that result. My 97 Z28 and 04 Z06 were so similar and disappointing that I can't really understand the logic. There's a significant industry in making the C5/6 interior decent. By all means, to each his own though...
I bet if you thought outside the box, with Miata, or Cadillac CTSV, something like that, you'd end up with a nicer end product.
Having said that, the easy way I would THINK, would be to take the motor, computer, harness, everything, from a donor and go from there.
I sort of went the other way- my car has a vary diversified ancestry!!! Did use the same vintage (late 60's)-but incorporated the stock Corvette gauges-
Mimicked a Lamborghini Miura
Still a work in progress-
Covered in leather-
Covered in leather-
