Side seat stud acorns?
What's the best way to keep the acorns on that holds the plastic trim on over the seat pivots? I bought a new set awhile back but keep finding them on the floor. It seems like after I pressed them on they were loose to begin with so I squeezed in rope butyl in the hole them pressed it back on. It seems to help but what would be a permanent solution?
Had the same problem on my 81. Every time I opened the drivers door there were acorns on the floor & under the seat. So, I removed the seat cushions and took out all the screws that have the acorns and then I threaded (10-24) the ends where the acorns go. I used nylocks and a pair of long nosed needle nose pliers to put the nylock on. I used chrome nylocks and it looks good.
I got rid of those POS things. I replaced the the bolts and put real theaded acorns on.
