1973 engine removal
Old 07-06-2015, 01:38 AM
Sam Phelps
Sam Phelps's Avatar
Default 1973 engine removal
need help... does anyone have a good link to a video on how they took out there 5.7 liter from their 1973 vette? and maybe a video on what to do to the engine when you have it pulled?
much thanks
Old 07-06-2015, 07:41 AM
AirborneSilva
AirborneSilva's Avatar
much thanks
I don't have a video but can tell you that you pull the engine from the side not the front and as for the engine, buy an engine stand
Old 07-06-2015, 09:42 AM
DonnieP73
DonnieP73's Avatar
I don't have photo's of removal, but I went to local rental and
rented engine hoist to remove the engine. I worked on engine
first and it was on engine stand (which I bought) for 2 years
while I worked on my 73.
Donnie
Old 07-06-2015, 10:09 AM
Chinaski
Chinaski's Avatar
St. Jude Donor '14
Manual or Automatic?
I pulled mine (Manual) with the trans, from the side.
Drain Oil
Drain Antifreeze (radiator and block drain)
Remove Alternator and Bracket(s)
Remove Power Steering Bracket from pump and block, lay pump aside.
Remove AC bracket, lay compressor aside.
I pulled my radiator, but I was installing a new one.
Remove fan and clutch
I removed my water pump.
I removed the carb to use a plate on the manifold to hook hoist to.
Remove distributor.
Remove Oil Pressure sending tube. (back of block near firewall)
I removed my headers.
Remove starter motor and mark wiring (important)
Unbolt driveshaft from yoke.
Remove yoke install tailshaft plug
Motor Mount Bolts (2)
Trans Mount Bolts (2)
Block to frame ground(s)
Pull Motor.
That's about it I think. Take pictures and label stuff, it ain't rocket surgery.
The
Old 07-06-2015, 01:02 PM
gungatim
gungatim's Avatar
much thanks
what to do once it's pulled is completely dependent on why you pulled it in the first place...if it's leaking, replace the seals and gaskets. if it's dirty, wash it and paint it. if it needs a rebuild, rebuild it. if it's a dog, put in a cam, new heads, intake, maybe a twin-turbo setup.
Old 07-06-2015, 02:48 PM
Condo_454C3
Condo_454C3's Avatar
Where are you located? I don't mind lending a hand if you are somewhat local
Old 07-06-2015, 03:01 PM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Mine was hooked to an automatic transmission. I too pulled it from the side. I left the tranny in the car and left it to sit on a steel pipe that was resting on the frame rails. This allowed me to roll the car outside and power wash the engine compartment in the driveway.
I used a Harbor Freight engine stand:
Best Choice Products SKY359 Engine 1000 lb. Pro Stand Hoist Lift Automotive Tools Shop Equipment New - Engine Stands And Engine Hoists - Amazon.com Best Choice Products SKY359 Engine 1000 lb. Pro Stand Hoist Lift Automotive Tools Shop Equipment New - Engine Stands And Engine Hoists - Amazon.com
Old 07-06-2015, 03:25 PM
corvetteronw
Cruise-In VIII
Here is a decent video that tells you how to deconstruct a 350. There are more videos in this series too.
Old 07-06-2015, 03:30 PM
Z06FEVER
Z06FEVER's Avatar
Here is a pic of removal.
To 1973 engine removal
Quick Reply: 1973 engine removal
