3:73 vs. 3:08 Rear End
TKO 5-speed with a 3.08 rear in my '80. The car has been resto-modded as a highway cruiser. I'm way past the age of smoking tires so this is the best arrangement for truly enjoying my baby.
I have 3.36 with a wide ratio.
70MPH is just at 3K. Not bad but at 85MPH thing sound a little more hurried.
I looked at doing a TKO and with the .82 overdrive it just didn't seem to be enough.
1:1 @ 70MPH is 2927
.82 @ 70MPH is 2400
.64 would have been too low at 1873 but with better rear gearing like 3.73 it would be perfect.
1:1 @ 70MPH is 2927
.82 @ 70MPH is 2400
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My factory setup was an M21 and 3.70s in the rear. I was young and stupid at the time, and the higher cruising RPM didn't bother me much. I eventually put a 5 spd and 3.08 in it. Nice cruising RPM and lots of torque off the line. However, I recently put the M21 back in the car (to take 30# off the car, as I like to do track days with it), but kept the 3.08 rear gears. Even with a lightweight 10.5" flywheel & clutch setup the car is easy to drive off from a stop (it's a big block though).
My 69 BB and my 70 BB each came stock with 3.08:1 differentials. This worked out well with the extra torque of the BB's. When I replaced the BB in my 69 with a clone L88, the 3.08:1 and the L88 cam shaft were not a happy couple. A lot of fuss getting the 69 rolling. I replaced the Muncie in the 69 with a Richmond 5 speed. The Richmond had a 1:1 fifth gear, but a lower (numerically higher) first gear...happiness. The 70 currently has a 3.73:1 diff and a TKO600 five speed.
The Richmond 5 speeds have 1:1 fifth gears, the TKO600's have overdrive 5th gears.
My '74 454 with a close ratio 4 speed runs 3k rpm at 77 mph, I don't do much highway driving, it'll do burnouts when I dump the clutch though!, it's fun to drive though.
I'm building a low rpm big power motor for it now, but, if you want to trade rears then let me know........
You have 3:70's not 3:73's There is a difference. And just so you know it doesn't hurt anything to go from 1st to third , it just feels like a normal wide ratio transmission .
I go 1st to 3rd, even 1st - 4th. M20-3:55-383. Lots of low end grunt. If I feel like rowing the gears, I'll do that too. Our freeway speeds are 65 mph in town and 75 mph at the city limits. I see an overdrive in my future.
Finalist 2021 C3 of the Year - Modified
I have a mild 350 with mods, TB 400 and a 3:08 gear
If my tack was working it would read about 2,300 rpm at 60 i think.
A 6 speed has 2 over drive gears 5th ~ .8 and 6th .64 - .5
4th is still a 1:1 like what you have.
Now I'm getting somewhere. When I bought my car I was told that they thought the rear end gears were 3:73's but over the weekend I was talking to a guy that knew the car and the guy a couple owners back that changed the gears and he said that they were definitely 3:90's instead of 3:73's so it's even worse than I thought and explains why it seems so low. The numbers on the rear housing say it was originally a 3:36 gear rear so I decided that is what I want to go back to. The same guy was telling me that if going from a 3:90 to 3:36 that there might be a difference in the size of the carrier maybe needing shims between the carrier and the gear. Can someone enlighten me on this and recommend what I will need to order.
#33
This thread is driving me crazy. I'm not looking to offend anyone and I've been criticized for doing this in the past but I have to point out that the correct terminology for gear ratios is 3.08, 3.36, 3.55, etc., NOT 3:08, 3:36, 3:55. This is a number, not a time of day. It is derived from dividing the number of teeth on the ring gear by the number of teeth on the pinion gear. Like 37/12 = 3.08 or 41/10 = 4.10. Some confusion probably results from the full mathematical terms for a gear ratio as in 4.10:1. There the ":" is short for the word "to". But we normally talk about gear ratios in shortened terms so 4.10:1 becomes just 4.10, hopefully.
#34
#35
As far as 3.90 gears, there may have been some aftermarket sets but no factory 3.90 gears that i know of.
Are you sure you have an M-21 trans and not an M-20?
#36
I run a T5 with a .63 overdrive in my C3 which is great and you should consider something like that. On the other hand, many years ago, I had a '63 Biscayne with a 409, an M21 and 4:11's. It was fun, but ridiculous as an everyday driver. So I put in a set of 3:08's and it solved the problem. Kept the 4:11's for racedays. Those old third members could be swapped out in a hour.
#38
For years I would skip second gear, first to third and then fourth. I had my M-20 rebuilt and third gear was really worn badly. I was told to use second gear, that it is a lot beefier gear than third gear. Been using second gear ever since. Lou.
#39
There are 3 carriers and 4 carriers. All 3.XX gears fit in a 3 carrier and all 4.XX gears require a 4 carrier.
#40
