1973 corvette rear drum to disk brake conversion any1?
#41
Maybe something like "hermanos locos"?
#43
Why get all that?
Don't I just need the trailing arms, how about off sets? completely assemble plus rotors and calipers? In any case that I need this thing instead I have a friend that imports used parts to cr all I have to do is ship it to his address in Orlando and he takes care of the rest. Thanks for the info on that.
#45
Seems like everyone...
Is more interested in making fun of the thread than helping. So if you guys want to talk about the fact that it has drums instead of rotors. So wake up call for the ones that just want to make fun of it. 1 stop being jealous of the fact that I'm restoring my dads car. 2 u.s.a cars have a lot of bad reputation outside the states in Costa Rica is very rare to see American cars and specially back in those days. Who ever brought this to Costa Rica might not have realize what he was getting into. As a fact up until 2005-06 it was really hard to find any type of spare part for American cars. So actually who ever did that was just trying to keep the car running at a high cost but it kept it running. Just like in Cuba perfect example where people has adapte and create their own parts to keep the cars running. So please stop laughing and start helping if not better don't coment. Now any1 interested in solutions is really welcome. Thank you. Stop hating haters!!!
#46
#48
TA=Trailing Arm.
The transverse leaf spring that goes from one rear wheel to the other is the spring I was referring to.
By the way, this is what you need to convert from drums to discs. http://www.ebay.com/itm/like/380266766872?lpid=82&chn=ps
#51
The spring and rear suspension should look like this when jacked up in the air.
#53
#54
At minimum I see:
T/A's x2 (L and R) Complete with disk brakes (what E-brake hardware do they come with?
Stainless T/A shim kit with bolts (enough for both sides)
4 Shocks (F and R)
6 Ujoints
Rear spring (fiberglass) and mount kit
Sway bar bushings
rubber brake line kit (front and rear)
Caliper rebuild kit (o-ring style) or a bolt on kit from Willwood (?)
A gallon of some type of rust penetrating fluid (I see lots of wrecked knuckles under that car.
Possibilities:
Id suspect at minimum a diff fluid change. Rebuild depending on condition.
Rear diff HD cover (check for cracks)
Have a look at:
Body mounts (#2), now bad has the salt air or moisture eaten away the body structure?
Steel fuel and brake lines running front to back
#4 body mounts (inside the rear wheelwell)
Frame condition under doors and in front of the rear wheel
I think that's going to be enough of a financial shock.
You said you wanted to rebuild this at whatever cost, Be prepared, your wallet is in for a rough ride.
dodosmike
4 Shocks (F and R)
6 Ujoints
Sway bar bushings
Possibilities:
Have a look at:
dodosmike
#55
The above list would apply to about any 40 year old car. Unless all that stuff had already been replaced.
#56
http://www.vtechcorvette.com/Trailing-Arms.html
You only need one of those kits -- it includes everything you need for your brakes, both front and rear. Based on age, you might also need a power brake booster (if the car is equipped with power brakes). Boosters sell for about $75 from RockAuto.com or $200 from the Corvette specialty outlets.
#57
Lol. Thanks
At minimum I see:
4 Shocks (F and R)
6 Ujoints
Sway bar bushings
Possibilities:
Have a look at:
dodosmike
4 Shocks (F and R)
6 Ujoints
Sway bar bushings
Possibilities:
Have a look at:
dodosmike
#58
Thanks for the link
Yes, you can get complete rebuilt trailing arms without the rotors from several sources. The one I used and can recommend is Vtech Corvette. A pair would run about $1,040 plus shipping.
#59
A suggestion about rebuilding the rear end. I'd recommend a composite rear spring from VBP. It weighs 8 pounds versus the 41 pounds for the steel spring, plus its soooo much easier to install than the steel spring.
#60
Yes, I know the cost.
At minimum I see:
4 Shocks (F and R)
6 Ujoints
Sway bar bushings
Possibilities:
Have a look at:
You said you wanted to rebuild this at whatever cost, Be prepared, your wallet is in for a rough ride. 17x8 wheels plus tire set. The paint,workmanship and upholstery. My dad will do it in his shop. So as long as I stay under $9000 in parts I'll be ok. We got the car for $5000 the guy was desperate and the car was deteorating and it was park in the street. So I guess this thing fix plus what we paid for it goes around $14-17k still a pretty good. A few years ago some guy offer my dad $20k the way it was so imagine fix. Like I said this things are worth more there cause they tend to be pretty rare.
dodosmike
4 Shocks (F and R)
6 Ujoints
Sway bar bushings
Possibilities:
Have a look at:
dodosmike
