Roller paint job
#42
What kind of hound? Looks a little like a weimaraner.
For those going to attempt this - don't skimp on the rollers (spend that extra $5, ha!). And always clean them beforehand to avoid any foam specks. I found it helpful to have use 4" roller loaded with paint to apply, and then a 2" roller going back over using only the weight of the roller to smooth and even out the paint. I got to where I was using a roller in each hand.
You can also use a cheap harbor freight hobby sprayer for the hood channels, door jambs, and other small places instead of a brush. I had a hard time finding the right ratio to use a brush and have it stick on vertical surfaces.
persuader (03-01-2016)
#44
Yep she's a Weim. She has to slouch to keep her head low enough to see out the windshield. I get some funny looks when people pull up and see a dog instead of a person.
#45
Very nice! What did you use for the paint?
I tried to do a custom color and used my stock hood as the test, but it turned out pretty lousy. Not sure what went wrong with it, may have been the generic white base I used.
#46
For the roof, just rustoleum oil base white, for the body 3 parts white to one part rustoleum oil base brown. Used 5 quarts and I still have almost a quart of touchup left over. Total cost, approx $ 150, but that included $60 worth of compounds for which I used less than half.
#49
1. cost. Rustoleum costs about $9 a quart. 3-4 quarts will paint a car. Even single stage acrylic will cost you $150-200. Base and clear coat urathanes costs more like $300+.
2. Equipment. Even though HVLP guns can be purchased pretty reasonably, you must have some kind of spray booth to do decent job which most of us don't. I've shot a paint job in my garage, and even after covering, masking, etc, there was still overspray mist everywhere. I swore I'd never do that again. Did a partial spray job on my driveway, and still had to deal with specks and dust and overspray.
3. Talent. To roll a car you don't need talent, just a lot of sweat and elbow grease. It's a labor of love with the emphasis on labor.
4. Time. When you spray a car, you're on a time schedule, a lot of planning and timing is involved. When you roll a car, there's no rush, you can do a couple hours work a day, take a month if necessary.
5. Mess. There's no overspray, minimal masking, no smell, The only mess involved comes when wet sanding and compounding, which cleans up pretty easily.
6. Touchups. Touchups are painless. You don't have to be afraid of scratches and scrapes. Touchup paint is part of the package; it's easy to blend. Color matching parts, like brackets, rims, is also easy.
7. Durability. Although Rustoleum is a little soft for 6+ mounts, the paint is thick enough that it can be color sanded or clay barred many times over. My 10 year old paint job still shines, while many 10 year old cars have clearcoats that are already worn through.
8. Last but not least, pride. People will be amazed at the results and you'll have the pride to say you did it yourself.
Obviously, a $30k+ car deserves a paint job to match. My C3 is a driver, not a showcar (although it did take 1st place in a show and shine), I don't have a fortune in it, and I am not a rich man. In my case it made sense.
#50
I work for an industrial supply company, so I just emailed my Rust-Oleum rep about this. Turns out he painted his motorcycle with their urethane paint. I'm trying to find out if I can possibly color match to my existing fire engine red paint. I need a temporary paint job that will last until I can begin a frame off resto at which time I'll repaint.
#51
Several reasons:
I ran my 66 in black wet sanded primer for all the same reasons and my 69 will be in the same because I just happen to like it...
With the 66 every show I was at and I was the only primered car allowed in at old town in those days someone would ask "when you gonna paint it" I would even have car painters all but beg me to allow them to paint the car I would always say...when you will paint it for free I will bring it to you...no takers.
#52
Okay...makes sense,
#53
Last time I went the people who did control the back land were charging to park and the attendants were nasty foul mouthed jerks, not OT's fault but it makes them look bad.
Things like all the c2's and c3's and herd of Cobras do not show up like they did,
Last time I had the 69 there ( 73-79 front clip ) a fellow had a fit that I parked next to his "real" 73.
When I get going again I will hit it but sadly it's not what it once was...
#54
#55
I'm in the middle of rolling on my paintjob right now too. She's been sitting for years and I finally just got her up and rolling and finishing up the paint now. Here's some pics of the 1st full coat, should be done in a few weeks. I think it looks fantastic, especially for $100. By the way, I ended up choosing Interlux Brightside instead of Rustoleum as it's made for fiberglass (boats), has a higher shine, and is supposed to last much longer than Rustoleum. It's a little pricier and there's only a few color choices, but so far I'm thrilled with it. Hope to post some final photos soon.
#59
And that response is what makes it oh so worth it!
My neighbor says the same thing. Looked at me like I was crazy when I told him I was gonna paint it myself with a roller and then said "ahhh, I see you decided the roller was dumb and you're doing a real paintjob huh?" when he saw the first coat... Nope, that IS from a roller. Can't wait until the final coat is all sanded and polished out!
I promise you, this is with a foam roller and $100 worth of paint. Look it up... there's plenty of guys getting show quality results with rollers. Mine won't be show quality, but it will definitely be good enough and leaves me with a few more thousand to spend on other stuff!
Just to "prove it" to ya, here's my tools and here's one T-top that just got it's very first coat with roller marks and all.
