Exhaust manifold cracks
What's the easiest fix for this?
Does that liquid steel work on filling and fixing these cracks?
How do you remove exhaust heat shields to get to these cracks?
they are not worth fixing. get a new one..depending on the year of your car, which you didnt mention, they are about $80 www.rockauto.com
orielly auto has them also, but a little more pricey
http://www.oreillyauto.com/site/c/de...haust+manifold
The manifold had just a crack not a completely broken off piece. The trick was to cut a large "V" along the length of the crack. Then welding it using a nickel rod. The weld can be detected if carefully searching for it as the nickel remained "shiney". But it's been ten years now and still fine.
