Big blocks...pix please
Old 10-08-2014, 06:37 PM
The13Bats
The13Bats's Avatar
Default Big blocks...pix please
I would like some pictures of big block engines I would rather have modded ones over stock but looking to get ideas,
Thanks!
Old 10-08-2014, 07:39 PM
Bullshark
Bullshark's Avatar
CI 5 & 8 Veteran
All Aluminum Dart 540 Big block with Dart heads and super Victor intake modified for FI.....work in process.
Old 10-08-2014, 07:46 PM
Ironcross
Ironcross's Avatar
Default My 68
1968 CORVETTE, Powered by L-88 crate engine
GM part number 3899643, cost, $1,247.00..... Dexter Chevrolet......Detroit, MI
1968 CAMARO L-72 Chevy suffix 'IP 427/450 HP
Fast, hell yes...otherwise they wouldn`t be here...besides jf you so happen to beat one of these. I` d just go home and get a faster one......
Old 10-08-2014, 09:54 PM
hwcoop
hwcoop's Avatar
Bored .030, decked, Line honed, ARP crank studs & fasteners Crank turned .010/.010, speed pro pistons (10.5 compression) Procomp heads(i'll let you know how they work out) Edelbrock performer intake, Headman 2" headers
Old 10-08-2014, 10:10 PM
RickyBerg
RickyBerg's Avatar
454cui.
Old 10-08-2014, 10:13 PM
RickyBerg
RickyBerg's Avatar
Originally Posted by Bullshark
All Aluminum Dart 549 Big block with Dart heads and super Victor intake modified for FI.....work in process.
Is that a road racing oil pan on that engine?
And dry sump?
Old 10-08-2014, 11:01 PM
pedec
pedec's Avatar
427/390hp ported, balanced, roller rockers, enlarged valves , but still all number matching and looks all stock.
Old 10-08-2014, 11:02 PM
pedec
pedec's Avatar
Other side and carb still needs rebuild.
Old 10-09-2014, 12:25 AM
jr9170
jr9170's Avatar
Location: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Received 1,069 Likes on 755 Posts
Great looking BB's, keep the pics coming...
Old 10-09-2014, 04:13 AM
Bad Bird
Bad Bird's Avatar
So, this one is pretty stock-looking. Actually it's an L36 with a small solid cam and the L68 tri power setup.
Old 10-09-2014, 12:57 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old 10-09-2014, 02:08 PM
TimAT
TimAT's Avatar
Crate LS-7 in a 69. Several changes since this was taken.
Old 10-09-2014, 02:49 PM
94hokies
94hokies's Avatar
Rebuilt 427 for '69. Had shop do low end performance package but still keep it on pump gas. Engine is in, car is in the shop now getting Vintage Air put in, and state inspection. Hopefully will have it on the road for the first time since I bought it once they are done.
Clearance with the DeWitt's dual fans in place and the original stuff removed:
Old 10-09-2014, 03:24 PM
Corey_68
Corey_68's Avatar
Before I swapped in the LS2...
Old 10-09-2014, 03:36 PM
1969RAY
1969RAY's Avatar
Not much stock here...
Old 10-09-2014, 08:44 PM
Bullshark
Bullshark's Avatar
CI 5 & 8 Veteran
We put this one on the engine dyno a couple months ago. 540 hp
Old 10-09-2014, 11:02 PM
Z06FEVER
Z06FEVER's Avatar
Here is my Big Block picture.
To Big blocks...pix please
FlyLS6
FlyLS6's Avatar
Default Engine
LS6 crate motor installed in 4/'78. 990 heads (10.2 compression with those heads), 198 intake under a 770 SA. 11,000 miles put on it in the last 36 years. All GM components except cam which is a detuned (relative to the factory LS6 cam) Crane; installed in 2005 during a refresh). Factory exhaust manifolds. 354 rwhp/400 rwtq. The hood down costs 2 rwhp (sitting still).
Old 10-10-2014, 12:06 AM
jr9170
jr9170's Avatar
Old 10-10-2014, 12:26 AM
jyounane
jyounane's Avatar
Default Work in progress...
...a few weeks from test run.
Joe
Quick Reply: Big blocks...pix please
