77 Horn problem
77 Horn problem
Hey guys,
So my horn started blaring as I was driving down the road the other day. I pulled over and just disconected the horn and got home to find the sleeve that the insulator sits in is broken (see pic).
I have done some searches and can't seem to find the fix.
Any help?
Thank you
Any help?
Thank you
you're going to need a new lower horn contact. they run around $20-$45. I believe most (if not all) of the parts vendors have it....as well as ebay.
Corvette Lower Horn Contact
#1 on this exploded view:
Thank you.. I have a generic Help unit I got at the parts store.. Just wonder if i should order OE part ot use this one.. It was only $6.
Thanks Again,
PapaJ
Thanks Again,
PapaJ
i'd say to compare it to the one in the pic, if it looks right, go ahead with the swap. If it didn't come with the spring, you'll have to swap that over. You might also want to get one of these: horn contact retainer. They are usual so brittle (if they haven't been replaced before) that they just snap into pieces. I speak from experience..lol
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
I hear Fantomworks will fix a '77 horn button for only $47,000.
