water pump question
Old 07-27-2014, 12:33 PM
red topless gator
red topless gator's Avatar
Default water pump question
Can someone tell me if the water pump on a 74 350, L48 is the long or short? I an wanting to get either a polished aluminum or chrome one.
Tjanks
Old 07-27-2014, 05:34 PM
Ironcross
Ironcross's Avatar
No Vettes use a long water pump regardless of the engine.....if you use the long pump its wrong.....
Old 07-28-2014, 09:08 AM
red topless gator
Thanks for the reply, advance auto listed the long, and I thought that was wrong. Thanks!
Old 07-28-2014, 03:28 PM
dochorsepower
dochorsepower's Avatar
Corvettes also have the larger 3/4" diameter shaft.
Old 07-28-2014, 05:20 PM
gerry72
gerry72's Avatar
That's part of it. The whole story is the '71-'82 smallblock Corvette pump is unique. Beyond the larger pump shaft, it is also 3/8" longer than the short pump. This means the existing accessory drives will not line up if you try to use a standard Chevy short pump and the fan clutch flange will not pilot on the hub.
Old 07-29-2014, 11:33 AM
Dustup7T2
Terrorizing Orange Cones
Support Corvetteforum!
Dustup7T2's Avatar
Originally Posted by gerry72
That's part of it.
Yes, a unique issue for our beloved mechanical SBC water pumps in those year cars. Don't be led astray.
To water pump question
Quick Reply: water pump question
