Muffler pipe guru's I need you help
So I'm putting on a 2 1/2" exhaust kit from Corvette Central, I didn't want to put the U bolts on it so I went and bought 2 1/2" band clamps but it appears that 2 /2" band clamps don't fit 2 1/2" pipes, they are too small. What size should I get? thanks for the advice/help
What is the inside diameter of the band clamp? The pipes you have probably have a spread joint so one pipe will slip over the other. Not sure if band clamps will work, but a 3 inch is probably the next size up.
http://www.autozone.com/autozone/acc...er=260503_0_0_
