speaker wiring
speaker wiring
I have a 79 and I would like to have an idea of the speaker wire colors before I start replacing things. I can find the front, but in the back all I have is wires. any help is appreciated. Thanks.
Received 1,469 Likes
Cruise-In II Veteran
Do you have the optional rear speaker set up in your 79 RPO U81? IIRC, the stock wiring was blues (+) and blacks (-).
the rear speaker option is RPO code U81. If your car wasn't ordered with it, then you don't have wiring going to the rear.
IIRC stands for If I remember correctly
cool, IIRC ! but I have wiring and the colors aren't the same. Oh well, I will figure it out. thanks for the help. Jon
In either event, the green wire is (+) and the green/black is (-) for one of the speakers; gray (+) and gray/black (-) for the other. That seems to be a common convention for [modern] rear speaker wiring. That might indicate that your rear speakers & wiring were added later by a car radio shop.
Jon
