Seat latch
Seat latch
The little chrome seat release button came off from the back of my seat. Is it a big job getting it back in, does the back of the seat have to come a part. Any of you guys know how to do it....
Received 2,878 Likes
Hi n2m,
It's a surprisingly involved job to replace the button.
The reason is the screws enter the button from it's rear side.
In order to gain access the hard plastic seat back needs to be removed. Then the rear of the seat cover needs to be opened all the way up, to just above the button location, so the steel release mechanism can be moved enough to gain access to the back of it for the screws to be installed into the button.
Do you have the AIM for your car? It'll give you an idea of what needs to be done. In the 71 AIM it's UPC 1 (Seats), Sheet J5.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
This is from the 78 aim:
"Good luck" indeed..I did it awhile back and it was a royal PITA.....
Had to finally use some JB Weld to finish it, but it has held up works ok.....
And yes the AIM photo etc. did help...............Mine was/is a 78 also.............
mk's78 aka Mike
mk's78 aka Mike
Received 3,139 Likes
If your thinking of replacing the covers, now's the time.
M
