78 L82 Automatic....Can someone tell me where the oil pressure guage line connects to the motor? I have a small leak and want to check it to see if it is leaking there.. Thanks for any info..
Oil pressure sending unit is just above the oil filter.
Can I see it from above or will i need to be under my car ?
I can just barely see mine from above. Would be hard to see if it is leaking. It is very easy to see from underneath. Look just above the oil filter for the sending unit. Sending unit is bell shaped with one electrical connection going to it.
