Antenna HELP!?
Antenna HELP!?
I have a 79 with a bad antenna. I could use some help. The mast cable was broken, so I got a replacement mast. I put it all together, and hooked it up and it didn't run.
So, I tested the wiring coming from the replay, and it appears to be working correctly.
Then, I opening the antenna up and tried to bench test it. The motor would not run until I manually closed the appropriate electrical points inside the antenna. Then it ran fine.
Does anyone know what is supposed to actuate the points for this antenna. It appears that unless the appropriate set of points are closed, the antenna won't run. However, on my antenna, none of the points are closed when it is just sitting there, so the motor doesn't run.
Any ideas?
Thanks in advance for your help.
-Jim
Any ideas?
-Jim
Not a C3 but this may help
jim
