Need A Picture, Power Door Lock
I am adding power door locks to my '81 and need a picture of how the power door lock wire harness comes through the metal inner door panel, and where the ground connection is and what hole the wire harness retainer pushes into on the passenger side door.
I know ALOT to ask, but I just want to make it like factory.
Thanks in advance.
Thanks in advance.
Yep, checked the AIM and also the Service Manual...both just not quite detailed enough. Although I did find a picture of a door panel with power lock that has helped.
Lakeside49:yes that helps....thank you...the power lock harness comes out the bottom of the inner door panel??...hmmm....interesting.
Any chance you took a picture of the passenger side door so I could see where the ground connection is at and where the harness push-in holder goes in? Do not take the door panel off just for a picture for me....not worth the effort.
Passenger Side
Dave
Wow....that was so far above the call of duty! Many thanks. And yes I will definitely do this for another in the future. In fact I am going to take some pictures and store them.
So is there any reason to think that the wiring harness routing in your '82 has been changed from what was done in the factory? Again I just want to keep the routing factory.
Thanks once again.
Thanks once again.
I think, from talking extensively to the original owner that the only thing he did was change out the actuators and then added the foam. I am surprised at how little he did to the car, nearly a time capsule, for the 31.5 years that he and his wife owned it. Not even the door hinges or any other external moving parts had been lubed in its 43,700 miles, let alone wire routings to myknowledge
Many thanks again. I have routed the wiring harnesses using your pictures. The passenger side fit perfectly; driver's side is just a bit long...I had no idea as to what the factory length was so I guessed when I installed the new power door lock switch connector pigtail. Should not be a problem though....I just pulled the extra into the dash...do not want the extra in the door and risk getting snagged by the window movement!
