Cleaning the soft top window?
The Novus 1 should clean the oxidation off, which is what is causes the yellowing. My TR6's rear window was discolored and after using this on the inside and outside, it came back to clear. I bought it on Amazon.com, here, but I bet you could find it at most auto parts stores.
At some time, you have to throw in the rag. Had my original soft top replaced by Al Knoch. Replacement was a virtual duplicate of the factory. The original soft top frame had not been exactly installed at the factory. Al's installers adjusted the soft top frame...it's something I don't think I could have done. This was all done at one of Al's visits to Pomona, California (Fairplex) My rear window on the original top was so fogged, I just cut it out with a razor blade to safely drive to Pomona. To bad, these tops were designed before convertible tops were designed to use real glass.
FYI: To remove an old soft top, Al's first line approach is just to razor blade them off. When I said it was an original May 1968 Convertible soft top, the top was painstakingly removed. This increased the time to replace my top!! It was removed as to destroy as little as necessary (not withstanding that I had already razor bladed out the plastic rear window). Al said it would be documented for his business with the NCRS people. For example, if someone said his tops didn't have the correct factory stitching, he could show photographs from my top, etc.
You can try white wall tire cleaner on the white canvas itself. Might be able to get it to come back to a closer shade of white.
Is that the original dated top? Check the rear window for date code. If it is the original top and it is not too badly worn, I would consider leaving it on the car.
My 63 still has its original top, it has a few holes in the vinyl that I will eventually have someone try to fix, but the top fits like a glove and I barely have the car out of the garage in weather that the top would be needed.
Gary
Gary
Gary
Gary
Received 2,878 Likes
Thank you Alan. It looks like mine is original but I can't make out the date code, I'll check it tomorrow when I go 'visit' the car again. We're sooo close to bringing it home
Checked the date code in the soft top window today and it is 369 so March of '69.....it's the original top.
I also bought the Novus cleaner kit (bought it at the Harley dealership) and took it to the detail shop. I could see it was taking some off but I don't have much strength so Kevin is going to finish it for me, he couldn't believe it was removing anything from the surface after he had already tried.
We also dropped the hard top off at the upholstery shop to have the new vinyl installed and that should be done next week. I always wondered why the vinyl was missing since the tank sticker said it came with it but we found out today, you could actually see an edge of black vinyl next to the trim where the former owner simply cut the vinyl off of the hard top. Hopefully it will look like new when we pick it up next week.
