POR15 on exhaust manifolds - Cant see my #s!!
All,
I recently had a shop restore 1969 L46 numbers correct exhaust manifolds, sandblasted and then POR15 them.
The POR15 looks great, but the application looks very thick and the numbers are no longer visible. The numbers are completely covered and you cant even see where they are supposed to be.
I'm upset as I wasn't expecting this as a end result and I'm trying to manage my expectations.
The restoration shop is locally respectable but how do I know that I have the correct parts back? I don't.
I asked the shop mgr about it, and he pretty much said 'it happens.' I was so angry that I couldn't even see straight when I saw the manifolds...
Any experience with this?
Thoughts?
Andrew
Thoughts?
Andrew
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
When you brought the parts, did you say "I want to be able to see the numbers clearly when finished" or did you say, " I want my manifolds to be clean and painted and pretty?"
What seems obvious to some people (Corvette owners) is not necessarily obvious to a shop.
Some people get their engine blocks back from a shop and are horrified when they find the numbers are gone from the pad.
scrape the paint off the numbers, verify they are correct, then brush on fresh por15... simple solution... Hard to understand why it would be so traumatizing.
I had a similar problem when I had manifolds ceramic coated. The manifolds looked smooth due to the thickness of the ceramic coating. I had the coating removed. I ended up having Jerry Mc Neish (sp?) restore the manifolds. Nothing like being unhappy and doing it twice.
Bob
Bob
Thanks for the inputs. And, no - I didnt specify that I wanted to make sure the #'s are legible.
Lesson Learned.
I'm not sure if I'm going to scrap the POR and re-do or just move on.
Thanks again.
Lesson Learned.
Thanks again.
Manifold Coating
My guess is they got overly aggressive with the abrasive blasting. If these manifolds were severely rusted that might explain the situation.
I Jet Hot coated my manifolds and yes I will take a hit from NCRS but the hit is worth it to eliminate rust IMHO. All numbers remained intact.
Now if I had a high dollar original I might have decided otherwise.
Bill
Bill
