engine oil dipstick
engine oil dipstick
My 74 vette is not showing any oil on the dipstick. My oil pressure is fine and I have no leaks. Am I putting the dipstick in wrong. I notice that it doesn't go in as smoothly as some cars. Thanks
Is this a late "April Fool's" joke? If you don't see oil on the dipstick,
ADD OIL!
There are 4+ quarts of oil in a SBC sump. If that oil is low by less than 2 quarts (still way too low), it won't show on the dipstick but the engine will still have oil flowing and building pressure through the pump.
Do you ever check it?
ADD OIL!
My Suburban burns a couple quarts between changes. No leaks. No blue smoke. I'm guessing worn rings. Just a tiny bit each revolution. Just started this winter. I did a compression check about 10,000 miles ago and everything was cool. No change in running condition. Planning on doing another compression check (and check plugs) as soon as it's convenient. I guess my point is: check your oil frequently, even if you think everything is cool.
Its a new dipstick. It took two more quarts. Its burning it somewhere. no smoke out the tailpipe. May be rings, I don't know. If its not one thing its another. If it needs rebuilt whats the cost?
Wait a minute here. A new dipstick? Now just just so you know, there are different lengths to them. If you bought a dipstick from an auto supply store, they usually come with a dipstick tube as well. Did you check the length of the new stick against the original? Did you simply install the new stick in the original tube? This problem may simply be you have a stick designed for a short tube in the original, longer tube.
This has to be a "leg puller"....
Terrorizing Orange Cones
OK, I'll bite.
Especially with any motor vehicle installed with an internal combustion engine, transmission, suspension, electrical or braking systems... there is surprising information developed by the manufacturer and printed in the owners manual on regular maintenance schedules. By chance, did you receive one for your car when taking ownership?
If so, you will find a chapter or a table dedicated to maintenance interval periods, usually by mileage accrued or by time expired, on when to check certain sub-systems.
Really, it would be to the car's and your financial benefit if you could periodically, review that data.
It would help you more than some of us can, to begin the troubleshooting by establishing a solid foundation of where the problem lies, new dipstick notwithstanding.
Let us know what you determine. Good luck.
