Turn Signal bulb replacement
My left turn signal bulb may be burned out on my 1974 since the arrow light does not come on but the exterior lights blink. The right turn arrow works fine. I assume the bulb is behind the speedo. If so which one is it. Or is it located somewhere else in the back of the dash. Thanks
Received 2,878 Likes
Hi G,
I believe the rear of the 74 speedometer still looks like this.
Lower center hole for the left turn signal indicator.
You just might be able to reach your hand up from below.
Good Luck!
Regards,
Alan
20 gauge Light Blue wire I believe. The socket has prongs on it so it just pushes in and pulls out.
Good Luck!
Regards,
Alan
Thanks Alan, it makes sense now since I was able to get underneath the dash and pulled the bulb that you described the other day to see if the bulbs in the dash were blown (my dash bulbs are very dim). This one I was able to take it out and test it and it was good. Perhaps it blew out after I put it back in or I didn't put it back in the socket all the way. Thanks again Alan.
