A/C Fan speed not so good
I've spent all day repairing the A/C on our latest Corvette acquisition: 1978 Silver Anniversary Edition. After getting it converted to R134 and running everything I've found that the air doesn't blow particularly strong on this car. I haven't compared it against my 74 as it's still in the project phase. It's nowhere near the same air velocity as the 84 vette. Is this pretty normal? All fan speeds work, the A/C housing is clean as is the evaporator core. Is there a reasonably easy solution?
Thanks - it's getting really warm down here!
Received 1,468 Likes
Cruise-In II Veteran
There are several threads on the upgrade Easy Mike speaks of.
I read another thread about upgrading the ground from the blower motor. I went with a larger gauge wire and a different ground point. It helped quite a bit with the fan speed.
