81 temp
81 temp
my 81 runs from 120deg to 220Deg approx (as shown by temp guage on console) I also hear a slight metalic sound. how can i verify the water pump is bad, and what temp should it run??
Received 1,469 Likes
Cruise-In II Veteran
Your owner's manual explains operating temperatures. 195 - 210 is normal. 220 is not overheating.
The common sign of a failed/failing water pump is coolant loss from the weep hole.
Are you losing coolant?
Larry
C3 water pump
Its good to hear that 200-220 temp is ok and it never gets near red warning mark. the punp seems to have no wiggle and is not weeping water that i can see. I first thought the "tinging sound" was the ac compr but am now pretty sure its the pump.
