Adding Power Door Lock To My '81
YES, YES, YES.....I forgot to send you a text telling you. Parts arrived on Thursday just as you said they would.....and I got busy and cleaned-up the terminals, took out the power window harness out of the doors in my car.....you were sure correct....a royal PITA to separate those two....so I just used the ones you sent me for both power locks and windows. Installed the power door lock actuators and then installed the window regulators with new motors.
Friday was a very busy day....and sky was cloudy so it was a perfect day to work outside.
I recommend MY1991 as someone to buy parts from. Jeff is an honest guy...does what he says he will.
Thanks Jeff.....now I am just awaiting for the power door lock connectors to arrive from Willcox and then I can install them.
YES, YES, YES.....I forgot to send you a text telling you. Parts arrived on Thursday just as you said they would.....and I got busy and cleaned-up the terminals, took out the power door lock harness out of the doors in my car.....you were sure correct....a royal PITA to separate those two....so I just used the ones you sent me for both power locks and windows. Installed the power door lock actuators and then installed the window regulators with new motors.
MY1991: no I do not have power mirrors and would get them from you except this would require getting new door panels due to the hole in the panel where the manual mirror controls are at.
So have to live with the manual mirrors.
