Bleeding brakes?
Old 03-29-2014, 10:16 PM
alconk
alconk's Avatar
Default Bleeding brakes?
Ok over that two years I've been fighting the battle with spongy brakes on my 82 and finally found the culprit. Two of the four pistons were leaking in the right front caliper so I replaced both front calipers, new pads and brake lines. My question is do I have to bleed the complete system minus the MC or can I get away with just bleeding the fronts?
Old 03-29-2014, 11:39 PM
PeteZO6
PeteZO6's Avatar
You're due for replacing all the brake fluid, so you should bleed the entire system. If you have a turkey baster, or similar, draw out the old fluid in the master so you don't run that old stuff through the lines and calipers.
Since it's a dual system, you can bleed either the front or rear first (flame suit is on). Within each system, bleed from the most distant bleed screw to the closest to the master.
You can go through two or more quarts to get all the air out. In the end, it's just a hydraulic brake system, so you CAN remove all the air.
Pete
Old 03-29-2014, 11:45 PM
alconk
alconk's Avatar
The fluid in the car is clear because last year I bet I bled the system 4-5 different times trying to remedy the problem. That's why I was hoping to to bleed the fronts.
Old 03-30-2014, 12:51 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
If you bleed just the front calipers and the brakes feel nice and firm, leave it at that. Air from the front part of the system should not be able to get into the rear system.
Old 03-30-2014, 01:41 AM
alconk
alconk's Avatar
Just finished bleeding the front and they feel pretty good but will have to wait for a drive tomorrow.
Old 03-30-2014, 05:01 PM
alconk
alconk's Avatar
Well not the results I was looking for, same spongy brakes. If fact went out in the country and did a emergancy stop from about 40 mph and did not lock up and the brake light came on. I'm going to replace the rear calipers in a couple of days and see if that makes a difference. This is one thing I do not like about this car, it gets scary at times..
Old 03-30-2014, 05:17 PM
Capkunu
Capkunu's Avatar
I went through a 6 week brake 'lesson.' After replacing all FIVE calipers (one of the replacements was bad out of the box), front cross-over, lines, MC and power booster, I failed repeatedly to get all the air out, applying several bleeding methods in the process. Throwing in the towel, I brought a shop into the project. BADA BING! Three of my fittings were loose and sucking air.
I think when they're working well, these brakes are quite good. My car stops reliably in a straight line. But, for how long they'll remain that way- I can't say. From all I've read, brakes are among the top frustrations of C3 ownership.
Stay with it; success will be yours.
Old 03-30-2014, 07:44 PM
PeteZO6
PeteZO6's Avatar
When well and properly maintained, these brakes are excellent. They didn't really start giving problems when the cars were newer and driven regularly. Later when most of them were parked is when the problems started.
Pete
Old 03-30-2014, 07:57 PM
alconk
alconk's Avatar
I agree just wish I could get the spongyness to go away. I have replaced the booster, mc (twice) front calipers and hoses and now I'm going to replace the rear calipers. Go from there I guess.
Old 03-30-2014, 08:05 PM
7T1vette
7T1vette's Avatar
How old are the flex hoses (between hard lines and calipers)? Old flex hoses can disintegrate inside and give you all kinds of funky responses.
Old 03-30-2014, 08:08 PM
PeteZO6
PeteZO6's Avatar
Good thought 7T1.
I replaced my +35 year old hoses with braided stainless hoses. Made a huge difference in pedal firmness.
Pete
Old 03-30-2014, 08:22 PM
alconk
alconk's Avatar
Well last night when I replaced the calipers the original black hoses where blacking my hands badly but last year I bought a stainless hose kit from one of the vendors and replaced them with those just for the front. So when I do the rears those lines will get replaced as well. Yea the hoses seemed brittle.
To Bleeding brakes?
Quick Reply: Bleeding brakes?
