Steering column-Turn signal part???
2nd Gear
Hello, I was dismantling my steering column to reach the 4 main bolts and tighten them due to the column being wobbly. Heard that this is a very common situation, Got the bolts tightened down down also with some thread-lock. However the issue is as I was re-assembling the column, a part came out and I have no idea where it came from. I was just slipping the center column (that holds the turn signal mechanism on the left) and this small metal clip or spring fell out. Not sure if it was from something else or if it is in fact from the turn lever mechanism. I have searched and searched for a exploded diagram of the turn signal mechanism to no avail. Does anyone recognize this part??? Thanks in advance.
-Blueshoremario
-Blueshoremario
Your AIM should show all components. I agree with '75, Jim Shea is the expert on steering system assembly and has published a lot of helpful white papers. You might also try going to Wilcox websites they offer year specific white papers and install guides which may offer additional info. I have two early C3's and that part you show is not familiar, so might be a later C3 component. Good luck!
I've got Jim's papers , pm me with your email if you want them. Their full of info about the job you're doing.
http://jimshea.corvettefaq.com/wp-co...v24MY20123.pdf
http://jimshea.corvettefaq.com/wp-co...v03JL20121.pdf
I think that's a spring that goes under the "rack" that's moved by turning the ignition switch. It holds it up so the gear doesn't jump a tooth. Here's a picture of the rack.
http://willcoxcorvette.com/popup_image.php?pID=27249
The rack, sector, and the "grasshopper" spring are in the Wilcox pic above but not your leaf preload spring.
Jim
2nd Gear
That's it.
It is the "Pre-load Spring". I had to remove the center pivot pins (again) to gain access to it. Thanks to everyone's input!
Waiting for the new top bearing and the Horn Contact Retainer to arrive so I can finish out the re-assembly. Then on to the next with is testing and repairing the tach and the speedometer. The speed works, but the odometer does not move. It just makes a clicking sound.(annoying)
Thanks!
Thanks!
That's it.
Thanks!
Thanks!
