dead battery in 10-12 hours
I need help my fellow brothers and sister. About a month a go my vette was put down till I could fix a non electrical problem. The battery was never once touched.
Will I got the problem fix but for some odd reason my battery is being drain by something. I am not sure how it started. Before my half shift broke it was fine. After that it started to bleed out power. There are only 3 wire on my junction block, the battery wire, starter wire, and my new ac electric fan wire. (The new fans where install 3 months before the battery started to lose it charge)
Any help would be nice
It's either a bad battery or something is draining the battery. You're doing the best thing by getting the battery checked. However, you might want to make sure there is nothing draining your battery because even a new battery will go bad pretty quick if it's discharged and left there for very long.
It's easy to check for something draining it. Put an ammeter (VOM in amps mode) between the positive post on the battery and the positive cable. Don't try to start the car or anything because you will toast the VOM and or it's wires. Make sure you close the door and keep the ignition off. See if you get any type of reading.
Best way to diagnose a battery draw is to first remove the positive battery cable and place a test light between the battery cable and the battery terminal. Make sure EVERYTHING is turned off on the car, including the dome lights and ignition switch. If the test light lights up, you have a drain, if it doesn't light up you probable have a bad battery.
If the test light does light up and you have a draw, then you can pull fuses one at a time until the test light goes out. This procedure will help you to narrow down which circuit the draw is on. Then you can look at a wiring diagram to see what items are on that circuit to help find the draw.
Or do what I just did. Took it to the part store had it tested. It failed got a new battery now. I love warranty
It a 2 year old battery not sure why it would go bad but it does happen. Thank god I dont have to break my back tracking down a power leech.
Ill post here if my hope turns out false and it was a power leech. But for now new free battery and a sunny day drive time.
Put on a battery disconnect so when it sits, a quick flix of the switch eliminates any drain.
