which distributor?
which distributor?
my 1973 is having the engine rebuilt and I want to replace the distributor...any suggestions?..something reliable but not too expensive..if even possible?
engine: Chevy 402.
engine: Chevy 402.
I love my MSD stuff.
Folks will say that a well-adjusted points setup will run just as well. I don't disagree one bit.
The big benefit I was going for was having the spark occur over a greater range of engine rotation (Multiple Spark Discharge) and help burn off some of the unburned fuel that can get so stinky at idle. I just installed a ~290 duration cam in my car and I can say that it burns VERY cleanly at idle.
Pretty bulletproof stuff.
If you go with the 'simple' HEI dizzy with the 'box' built into the cap and use a 'simple' inductive coil, you could probably keep the costs down.
I have the billet tach drive unit with external 6AL box and capacitive coil with all their SuperConductor wires. The entire setup was ~$1,000. I really, really like it.
stock HEI
I do have a kit in the rear compartment as well but points/condensor do not suffer sudden failures. I just drive and enjoy without fear of micro-circuits burning out. A sadistic pleasure I suppose.
Here's what I'm using.
MSD 6AL Ignition Control
MSD Blaster Coil
MSD Pro Billet Distributor
MSD Red Super Conductor 8.5mm Wires
ACDelco Professional Platinum Spark Plugs
MSD Blaster Coil
I dunno, I kinda like the stock stuff.
I took all the MSD stuff off and run original points distributor and the original coil.
I think my brother rebuilt it once; I think he just wanted my $$...
I was thinking about buying a Summit HEI distributor with tach drive for my 70. It's advertised as being "blue printed" whatever that means. It's pretty close to $300 so it's not a $99 eBay special. Is it worth it?
It'll be going in a 496/502 BB. Probably about 10:1 compression. Does this appear to be a good dissy?
